11-07-2006 05:21 PM - edited 07-03-2021 01:12 PM
Can anyone provide assistance with loading a pre-existing CA Certificate on the WLC4400 ?
11-08-2006 01:17 AM
Hi Noel,
for what reason do you need the certificate?
If you need this external certificate for https setup use this link here:
Best regards,
Frank
P.S. Please rate helpful posts
11-08-2006 07:11 AM
We are using PEAP w/MSCHAPv2. In our environment we would like the Controller to authenticate terminals via Radius (Acting as an Embedded Authentication Server). Am I taking the wrong approach.
11-09-2006 02:00 AM
Hi Noel,
i hav actual no answer for this, but i will have a setup in my test-lab the next days for that.
Please be patient.
Best regards,
Frank
11-09-2006 09:14 AM
Noel,
You are coming at it a bit of an angle. The WLC will pass along the authentication to a AAA server as a NAS. So you don't need a certificate on the WLC itself, just on the AAA server and the client if you are verifying the certificate. It's not actually the controller that does the authentication since it does not have an embedded AAA server yet, that will be in 4.1 code due out next year.
11-10-2006 11:34 AM
Is there any way to beta test 4.1 ?
11-10-2006 11:52 AM
To my knowledge, there is not a beta at this time.
