Call Station ID field does not contain IP address for Guest clients on WLC code 7.5
Hi all,
if anyone has experienced the below kindly share your knowledge please
This missing information impacts the NGS location feature.
Workaround is to disable the Call Station ID check for the RADIUS client (WLC running code 7.5).
Fri  Sep  6 15:28:04 2013 : Error: Ignoring request to authentication  address * port 1812 from unknown client xx.xx.xx.xxx port 32769
Fri  Sep  6 15:28:08 2013 : Error: Ignoring request to authentication address  * port 1812 from unknown client yy.yy.yy.yyport 32769
thanks in advance
lance
Bronze
Re: Call Station ID field does not contain IP address for Guest
could you please elaborate more on the use case?
calling station id should be end point mac address and called station id is configurable on wlc , for ap mac:ssid, wlc mac: ssid, etc... wlc will send accounting pkts that contain client ip.
Hi Shaongin LI
before the In earlier 7.5 WLC  the IP address of a client connecting to a WLAN with no L2 but L3 security enabled was added to the RADIUS request. however now it comes up with following
_SYSTEM_
(   - a.b.c.d) User trying to authenticate from invalid location:userX 61369
09-Sep-2013   11:27:12
_SYSTEM_
Updated   guest account: userX 61369
WLC Settings are
RADIUS Authentication Servers
Call Station ID Type 1 [Ip address]
MAC Delimiter [Hyphen]
1.Call station ID Type will be applicable only for non 802.1x authentication only
NGS Settings
Edit RADIUS Client
Ip address: x.yz.a
Device Sends Calling Station IP [un tick ]
Re:Call Station ID field does not contain IP address for Guest c
He's talking about NAC Guest Services, which is a layer 3 Web Auth solution. In which case it would show the IP address in the calling station id.
Sent from Cisco Technical Support Android App
943
