Can I have more than two DHCP Servers in a WLAN?
I have introduced ISE into my environment and need to send DHCP traffic to it for profiling. I have two DHCP servers, however. I would like three fields for DHCP servers in a WLAN. Is it possible to add a third with the current configuration? I'm running 7.6.110.0. Thanks.
VIP Purple
As per my knowledge you can
As per my knowledge you can only enter 2 DHCP address(Primary and secondayr) for a specific WLAN(dynamic interface).
Bronze
The only way to have more
The only way to have more than two DHCP servers would be to disable DHCP proxy on the WLC and use ip helpers on the LAN.
Bronze
Hi,Yes,  Disabling the DHCP
Yes,  Disabling the DHCP proxy on WLC and us IP helpers on LAN switch is a option to have more than two DHCP servers.
97
