Can I use ASA to setup vpn tunnels for wireless clients?
Hi Forum,
We will be getting cisco WCS,WLC and APs. however, the clients are normal windows wireless clients.
Can I use my ASA5500 to provide security for my wireless client, by setting ipsec tunnels for wireless clients?
py
Blue
Re: Can I use ASA to setup vpn tunnels for wireless clients?
in short, yes.
your AP will be connected to the wired network at some point, as is your ASA.
this being the case, you can use your ASA to provide ipsec tunnels for your clients, either wired or wireless.
your topology should look something like the following for it to work:
wireless PC >> AP >> wiredNetwork >> ASA >> internet/outsideNetwork
if your topology is similar to the above, then you can use your ASA to provide ipsec tunnels for your wireless PCs to an outside network/internet.
(your AP should support ipsec if it is to be part of the tunnel; this is pretty much standard nowadays)
Thanks Gpulos,
I placed all my wireless clients inside the same vlan. When you are referring to outside network, can I say another Vlan?
My intention is to protect WEP clients or any wireless clients, so any traffic from the wireless vlan will be ipsec protected, going to the internet/ other vlans will be clear.
I am using cisco 3600 switch as internal vlan routers.
Any documents that you can recommend?
Thanks much,
py
108
