Community Member
Can't get CCKM running with LEAP
I am trying to setup clients to authenticate to my AP using CCKM and LEAP. I am currently able to connect using my Dell Truemobile WLAN card with WPA authentication and LEAP. When I try to authenticate with CCKM however, I don't even get a prompt for my credentials like I do when I authenticate using WPA. I have both CCKM and WPA enabled as mandatory for key management on the 1100 AP. Can anyone help point me in the right direction? Here is the debug I get when I try to authenticate using CCKM on the AP:
*Mar 1 00:48:57.980: AAA/BIND(0000009E): Bind i/f
*Mar 1 00:48:59.711: AAA/BIND(0000009F): Bind i/f
*Mar 1 00:49:02.201: AAA/BIND(000000A0): Bind i/f
*Mar 1 00:49:05.971: AAA/BIND(000000A1): Bind i/f
*Mar 1 00:49:11.214: AAA/BIND(000000A2): Bind i/f
*Mar 1 00:49:14.901: AAA/BIND(000000A3): Bind i/f
And my running config:
aaa new-model
aaa group server radius rad_eap
server 192.168.100.10 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
cache expiry 1
cache authorization profile admin_cache
cache authentication profile admin_cache
aaa group server tacacs+ tac_admin
cache expiry 1
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa cache profile admin_cache
all
aaa session-id common
dot11 ssid test
authentication open eap eap_methods1
authentication network-eap eap_methods1
authentication key-management wpa cckm
guest-mode
mbssid guest-mode
username test privilege 15 password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid test
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.100.10 255.255.255.0
no ip route-cache
ip default-gateway 192.168.100.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
no authentication mac
nas 192.168.100.10 key xxx
user xxx
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.100.10 auth-port 1812 acct-port 1813 key xxx
radius-server vsa send accounting
control-plane
bridge 1 route ip
1 REPLY
Bronze
Re: Can't get CCKM running with LEAP
The issue may be due to LEAP may be selected under the WPA option.To resolve this follow the steps.
1. Launch ADU
2. Click on tab "Profile Management"
3. Select the corresponding profile and click on the "Modify" button
4. click on tab "Security"
5. You should be given 5 choices: "WPA", "WPA Passphrase", "802.1x",
"Pre-Shared Key (Static WEP)" and "None". Select "WPA".
6. There is a pull down menu called "WPA EAP Type:" beside "WPA". Please
select "LEAP" from the pull down menu.
211
