Can't move AIR-CAP1602I-A-K9 APs to 2nd controller?!
Hi everyone,
We have two 5500 wireless controllers that we use for ~80 APs.  We just installed the new system a month or so ago.  When all the APs were replaced, they updated from the new controller and all joined the first controller.  I cannot get any of them (except 1) to join the 2nd controller.  I even set the primary controller to be the 2nd one on a few of the APs, reset them, and they still do not join it.
The only one that does join it is on VLAN 6 (wireless vlan) and all the rest are on VLAN 5.  I do not have a DHCP option set but from what I have been reading I was under the impression that I did not need to have one set with this model of AP.
I am fairly new to wireless so please forgive me but I do not know what information I need to provide you guys with to help me. If you are able to help, just let me know what I need to get for you and I can do that.
Thanks in advance!
Edit:  This is showing up on the 2nd controller for one of the APs I tried to force onto it.
"Layer 3 discovery request not received on management VLAN"
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Can't move AIR-CAP1602I-A-K9 APs to 2nd controller?!
You should have two entries that show UP, you only have one and if you do a show interface detailed management, you will see that that mac address is itself.  You need to add an entry for the other WLC.  This is how it should look.
Example:
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast IP     Status
00:1e:4a:ff:1b:20  *.*35.248    dummy                             0.0.0.0          Control and Data Path Down
7c:ad:74:8d:37:e0  *.*.71.248    dummy                             0.0.0.0          Up
7c:ad:74:8d:73:00  *.*.71.246    dummy                             0.0.0.0          Up
00:1e:4a:ff:25:e0  *.*.35.246    dummy                             0.0.0.0          Control and Data Path Down
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Bronze
are you putting ap in a dynamic interface vlan?
I believe they are connecting to a Dynamic Interface VLAN.
that is not a good idea.  The AP should be on their own VLAN, and it should not exist as a dynamic interface on the WLC.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
So you have two WLC's and they are on the same subnet correct?  Do you have mobility setup between the two wlc's and are they using the same mobility group name?  This is important if you want the AP's to know about the othe WLC.
Scott
-Scott
This is really a reply to both of you, and thanks for your help.  I do not know if mobility is set up between the two, and I am not sure how to check.  When we upgraded the wireless controllers, we copied the config from the old ones to the other.
They are on the same subnet.
I was part of the upgrade to the new controllers, but I kind of followed along and didn't really do any of the setup.  The network is now in my hands, though.
You can't just copy those... as it has the managment mac address tied to an ip address.  Look at these docs:
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a00809a30cc.shtml
http://www.cisco.com/en/US/docs/wireless/controller/7.3/configuration/guide/b_wlc-cg_chapter_01111.html#ID143
Scott
-Scott
Couple more links:
http://ccie-or-null.net/2011/02/16/cisco-wlc-mobility-groups/
Scott
-Scott
We went through and changed those to the new ip range and everything.  They work fine right now but the access points won't split between the two controllers.
Edit:  I know we never did anything with mobility groups, but each controller has the other controller in the mobility group.  It shows up when I run the sh mobility summary command.
You need to manually adding the primary and secondary. As long as the mobility is up between the two wlc's you should have no issues. They will not split up automatically. You need to go in the AP and under the high availability set the primary and secondary WLC information. It is case sensitive also.
-Scott
I have already done this, and they do not go to the 2nd controller.
Post your show mobility summary from both wlc's.
-Scott
Here is a link to a doc specific to setting and verifying ap failover. Ap fallback also needs to be enabled. Not knowing what you have configured makes it hard to troubleshoot.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008064a294.shtml
-Scott
Controller 1
Mobility Architecture ........................... Flat
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... dummy
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x7ae9
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 2
Mobility Control Message DSCP Value.............. 0
Controller 2
Edit: AP Failover is enabled.
So you can see here, that your mobility is not up:
So you need to fix this and your mac address, don't match?  The mac address of the top WLC is 7c:ad:74:8d:37:e0 and the bottom one is 7c:ad:74:8d:73:00, so both of these need to be in the mobility group configuration.
Scott
-Scott
Those are the old ones from the old controller, the new ones are up and say they are up on the 2nd line.
The ------------------------------ Line separates the controllers, controller 1 on top and controller 2 on bottom.
You should have only two entries.... one for each wlc.  So each wlc has to be entered in the other mobility group.
Scott
-Scott
They are... they just have the old mobility group in there from the old controllers.  But the new ones are still there and they say they are up and working..
Could you post it?
Scott
-Scott
I posted it a few posts ago.  I went ahead and bolded the important information.
Example:
Scott
-Scott
That makes more sense.  How come there is one AP that is able to get on controller 2 then?  Any ideas?  I will add this when I am at work tomorrow and let you know how it goes.
That is because it joined that WLC... now try to move it to the other WLC and you will run into the same issue... it will not move.
Scott
-Scott
This is what you need to do from the CLI:
config mobility group member add
Scott
-Scott
I did that and it lists them as
How do I get them to come up?
Are they on the same subnet, if not, make sure you have no acl firewall that so blocking the traffic.
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70mobil.html
-Scott
They are in the same subnet.
If they are in the same subnet and you have issues, then delete the entries and add them back. In each WLC if you are doing this from the GUI, the top entry is the entry for the WLC you are in, so you copy that and add that to the other WLC and vice versa. Sometimes it works when you remove everything and add it back.
-Scott
Also, you should be able to mping and eping from one WLC to another from the CLI. This is different from a regular ping. Make sure though you can ping the other WLC. If not, them you need to troubleshoot that.
-Scott
Removed all but the self entries, copied and pasted and still down.
Edit: I am able to ping the other entry with the little drop down box in the GUI
Edit 2:  They are up now.  Should I be good to go?
293
