08-24-2012 02:31 PM - edited 07-03-2021 10:34 PM
Can the Cisco 3602 APs be configured by a Cisco 5508 WLAN controller to provide client isolation?
08-24-2012 08:22 PM
Can you define what you mean by client isolation?
08-25-2012 12:40 AM
John: by client isolation, do you mean that you don't want clients on same WLAN to talk to each other?
If yes then yes you can do that from the wireless controller per WLAN.
This is a link about it and how it can be configured:
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html#wp1209597
Amjad
