Can we still use PEAP-MSCHAPV2 for authenticating to a WPA2-Enterprise network?
L.S,
For authenticating to a BYOD wireless network a lot of companies use WPA2-Enterprise connected to a Microsoft IAS/NPS server to authenticate against Active Directory. There seems to be a way to intercept this wireless traffic using a roque accesspoint using the same (company) SSID-name and tools like freeradius-WPE and cloudcracker.
If the BYOD client doesn't check the certificate provided by the fake radius server, the MSCHAPv2-negotiation can be discovered and the hacker will get the username AND hashed password which can be lookup'd by rainbow tables sites like cloudcracker.
Is there still a safe way to deploy AD-authentication to BYOD clients?
Kind Regards,
Arjen
1 ACCEPTED SOLUTION
You've just described the
You've just described the biggest issue with PEAP (MS-CHAPv2) deployments. Best practice should be RADIUS server certificate signed by an enterprise CA (i.e., not a public CA). Client should be configured to validate server certificate (Root CA must be installed on all clients) AND check RADIUS server names against a pre-populated list. The security of the network decreases from there. Worst case would be not checking server certificate at all. At that point, grabbing the MS-CHAPv2 handshake is trivial.
I have tested the WPA2
I have tested the WPA2-enterprise/PEAP-MSCHAPv2 exploit this week placing a laptop in my car on the company parking lot with a Kali image, using hostap and freeradius-wpe configured with the company SSID. It was very easy to find out the mschapv2 challenge/responses of a number of android/windows phones that there just walking past my car. Also iPhone has a bad WPA2-enterprise implementation (see: http://research.edm.uhasselt.be/~bbonne/docs/robyns14wpa2enterprise.pdf), so bye bye WPA2-enterprise/PEAP-MSCHAPv2.
Wonder what other (large) companies are using for their BYOD wireless networks! EAP-TLS using certificate sounds like the only feasible option, however, we are afraid that the enrolment of certificates to the BYOD-clients will be a total disaster. I heard stories that some android phones lose their client certificate after a reboot :(
2284
