04-08-2009 06:49 AM - edited 07-03-2021 05:25 PM
I have two SSID.
Is there anyway to configure in WCS/WLC that certain AP will only broadcast SSID A and the rest of the AP will broadcast both SSID A and B?
04-08-2009 02:28 PM
Yes you can.
It's called AP Groups. Create two AP groups. Put the AP's that will broadcast SSID A in one group and the second group will broadcast SSID A & B.
04-09-2009 06:27 PM
Thanks. it works
04-09-2009 08:07 PM
Thanks. Please rate when applicable/helpful.
