CAP1602i Dot11 radio status stuck on reset.
Hello all,
I'm using a 7500 wlc running 7.4.100.60 with cisco CAP1602i and the show ip int brief is as follows:
BVI1                       192.168.26.111  YES DHCP   up                    up
Dot11Radio0                unassigned      NO  unset  reset                 down
Dot11Radio0.1              unassigned      YES unset  reset                 down
Dot11Radio0.2              unassigned      YES unset  reset                 down
Dot11Radio0.17             unassigned      YES unset  reset                 down
Dot11Radio0.18             unassigned      YES unset  reset                 down
Dot11Radio1                unassigned      NO  unset  reset                 down
Dot11Radio1.1              unassigned      YES unset  reset                 down
Dot11Radio1.2              unassigned      YES unset  reset                 down
Dot11Radio1.17             unassigned      YES unset  reset                 down
Dot11Radio1.18             unassigned      YES unset  reset                 down
GigabitEthernet0           unassigned      NO  unset  up                    up
GigabitEthernet0.1         unassigned      YES unset  up                    up
Log for the AP is as follows:
*Mar  1 00:00:12.011: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:14.435: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:14.559: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:15.551: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:18.291: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.2(2)JB1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 07-May-13 09:37 by prod_rel_team
*Mar  1 00:00:18.291: %SNMP-5-COLDSTART: SNMP agent on host CFMLAP0102 is undergoing a cold start
*Mar  1 00:00:18.331: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:18.331: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:18.419: Starting Ethernet promiscuous mode
*Mar  1 00:00:18.627: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:19.451: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:21.715: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:47.115: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:53.899: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface BVI1 obtained IP from DHCP...
*Mar  1 00:00:54.019: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.26.111, mask 255.255.255.0, hostname CFMLAP0102
*Mar  1 00:00:54.019: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface BVI1 obtained IP from DHCP...
*Mar  1 00:01:03.899: %CAPWAP-5-DHCP_OPTION_43: Controller address 192.189.37.130 obtained through DHCP
*Mar  1 00:01:03.899: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:03.927: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:01:13.927: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Apr 17 23:11:35.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.189.37.130 peer_port: 5246
*Apr 17 23:11:35.323: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.189.37.130 peer_port: 5246
*Apr 17 23:11:35.327: %CAPWAP-5-SENDJOIN: sending Join Request to 192.189.37.130
*Apr 17 23:11:40.323: %CAPWAP-5-SENDJOIN: sending Join Request to 192.189.37.130
*Apr 17 23:11:40.423: Starting Ethernet promiscuous mode
*Apr 17 23:11:42.443: ac_first_hop_mac - IP:192.168.26.3 Hop IP:192.168.26.3 IDB:BVI1
*Apr 17 23:11:42.443: Setting AC first hop MAC: ccef.48fa.7a14
*Apr 17 23:11:42.959: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Apr 17 23:11:43.459: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller Burnaby-WifiController0
*Apr 17 23:11:43.503: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Apr 17 23:11:43.503: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Apr 17 23:11:43.503: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration file
*Apr 17 23:11:45.147: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
I can't seem to figure out why the lines that appear on other APs arent showing up on this particular one. Normally the AP after the IDS signature it'll show the following :
*Apr 17 22:09:43.043: %CDP_PD-4-POWER_OK: Full power - NON_CISCO-NO_CDP_RECEIVED inline power source
*Apr 17 22:09:44.115: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 17 22:09:45.115: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Apr 17 22:09:45.171: %DOT11-6-DFS_SCAN_START: DFS: Scanning frequency 5280 MHz for 60 seconds.
*Apr 17 22:09:45.175: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr 17 22:09:45.183: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Apr 17 22:09:45.191: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Apr 17 22:09:46.223: %DOT11-6-DFS_SCAN_START: DFS: Scanning frequency 5280 MHz for 60 seconds.
*Apr 17 22:09:46.227: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr 17 22:09:47.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Apr 17 22:10:46.283: %DOT11-6-DFS_SCAN_COMPLETE: DFS scan complete on frequency 5280 MHz
152
