For CAR AAA service properties, "Type" is one of the required field that need to be filled.
The options either to use eap-leap, eap-md5, eap-sim, file, group, ldap, local, odbc, radius,
radius-session, rex, or tacacs-udp.
Question:
1. If CAR need to be integrated with LDAP, will the data retrieved/exchanged between CAR and LDAP be encrypted? Or can I have only the password portion
encrypted, while "username" sent in cleartext?
2. MD5 (one-way-hashing) is part of the hasing algorithm supported by CAR. IF I were to use the MD5, will the other end (LDAP) able to reverse the hashed value?
AK
