Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CCMP DecryptErrorsClient is detected (WLSE&AP)
I saw these errors(faults) in wlse.
And I saw "Decrypt Failed" in AP
Does anyone know why these fault appear?
How does "Decrypt Failed" occur?
in WLSE
Fault Summary
Type: Client_stat 000d0bXXXXXX **SSID**
Description:CCMP DecryptErrorsClient is detected (cnt: 2)
Severity: P2
Timestamp: Active 02:51:10 10/23/2009
in AP
HOSTNAME#show dot11 associations all-client
Address : XXXX.XXXX.XXXX
IP Address : YY.YY.YY.YY
Interface : Dot11Radio 0
Device : unknown
Software Version : NONE
CCX Version : NONE
State : EAP-Assoc
Parent : self
SSID : *************
VLAN : 81
Hops to Infra : 1
Association Id : 37
Clients Associated: 0
Repeaters associated: 0
Tunnel Address : 0.0.0.0
Key Mgmt type : WPAv2
Encryption : AES-CCMP
Current Rate : 48.0
Capability : WMM ShortHdr ShortSlot
Supported Rates : 1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
Signal Strength : -64 dBm
Connected for : 74579 seconds
Signal Quality : N/A
Activity Timeout : 25 seconds
Power-save : Off
Last Activity : 35 seconds ago
Packets Input : 103944
Packets Output : 12239
Bytes Input : 7375508
Bytes Output : 8153308
Duplicates Rcvd : 4607
Data Retries : 2952
Decrypt Failed : 5
in this FAQ, I can understand Fault in wlse appeared because I use IDS setting in WLSE.
But I can't set "threshold" in wlse (IDS > Manage IDS Settings > CcmpDecryptErrorsClient)
I can only set polling time.
http://www.cisco.com/en/US/docs/wireless/wlse/2.12/troubleshooting/guide/faults.html
And I can't understand why this "Decrypt failed" occur.
544
