Community Member
cert
Hi, I have installed third party certificate for web auth for guest users,
can I use the same cert for management? where I login at https://controller.ip.address.x ? so i don't get the ssl warning?
Thank you.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: cert
For h-reap yes. You need I upgrade to 5508's or WiSM2's with the environment you have. Of course your AP's are kind of old:)
-Scott
Re: cert
Since most 3rd party certificates are chained certs, you would not be able to use them for management.
Note: Chained certificates are supported for web authentication only; they are not supported for the management certificate.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a77592.shtml
-Scott
Community Member
Re: cert
Thnx dude
Re: cert
No problem. It would be nice if the wlc could use them.
-Scott
Community Member
Re: cert
Ok here is what happened.
I have created a Cert Signature Request for guest.mydomain.com from godaddy[.]com, they sent chained certs and their root, so Device,Intermediate,Root combined that and created a final cert with my key and all that.
The guest page has 1.1.1.1 as an IP address so I've added a dns record guest.mydomain.com => 1.1.1.1 now when users go to guest page they don't see the cert thing warning, works good.
I wanted to play with it and I changed DNS record guest.mydomain.com => 10.10.10.x or whatever my management IP for the WLC, and went on WLC clicked MANAGEMENT ---> HTTP/HTTPS (on the left) I have HTTPS enabled and HTTP disabled, downloaded the cert via TFTP server, worked.
next thing i go to https://guest.mydomain.com the managemend interface comes up without a SSL warning or what so ever, so it kinda works but you need two certificate with FQDN. one would be guest interface and another would be management interface, since they have different ip addresses they required different FQDNs.
Tadaaaaa
P.S If I used CISCO ISE as a wireless guest portal it would be possible to use the cert for webauth/management at the same time since it's the same ip/domain and they would also work with posturing/installing NAC agents, so 300 usd from godaddy for 5 years is not bad.
cert
One other thing you can do is use a wildcard cert.  This way you can have two FQDN and use one for webauth and the other for management.  That works because I have done that, I'm guessing you might also be able to use the SSL certificate you use for guest, just create another host record in DNS pointing to the management ip of the WLC.
-Scott
Community Member
cert
Thanks dude, by the way do you happen to know when did WLC start supporting ISE in H-REAP/FLEX mode
I can't upgrade to the latest version of WLC because I have like 700 1231 AG APs unfortunately and that's killing me.
thank you.
Re: cert
I believe in 7.2.110.0 which is MR1.
-Scott
Community Member
Re: cert
Does this mean I cannot profile clients they are doing local switching if i don't have anything 7.2 and up?
Re: cert
-Scott
Community Member
Re: cert
I know they are old lol and there is a really bad thing going on that stops me from upgrading the WLC, I will have 3500 new APs in the office, to provide employees corp access, and provide guest network - wich would go through their DSL.
With that in mind here is what I have:
WLC 5508, Software Version                 7.0.220.0
ISE 1.1.1
Warehouse APs 1231AG converted to LIGHTWEIGHT ( no HREAP, don't care much about profiling and posturing here, but they are centrally switched so no problems for them)
1 AP 3500s in the office to provide GUEST(through their DSL Line) and CORPORATE(locally switched), profiling and posturing included, at least profiling for now.
I am sorry I'm all messed up from reading different documentation, because they were developed in different time frames supporting different features.
doable?
Re: cert
It is doable... You might want to upgrade to 7.0.235.0 which I believe is the latest. You can profile your internal since its local mode.
-Scott
Community Member
Re: cert
Yeah that's the latest, Im gonna upgrade to 7.0.235.0, thanks, eventhough the ones that connect to the 3500s AP in the office are not comming with capwap all the way to the core they are locally switched at the remote site
Re: cert
Well for your setup, centrally switch is supported IIRC, but locally switch is not unless your running MR1 and ISE 1.1.1.
-Scott
771
