Certificates and High Availabity Mode
Good Day All,
I have a pair of 5508 Wireless Controllers running in High Availabity mode.
I need to install a certificate on the controllers that will allow the administrator to login to the devices without the standard security error.
Does anyone know if I can load the certificates directly onto the High Availabity pair or is I have to take them out of High Availabity before I can install the certificates.
Any help is most appreciated.
thanks so much
regards
amanda
1 ACCEPTED SOLUTION
If you do so it will always
If you do so it will always be pushed to Active one only, not synched to standby. So you have to do that separately.
Thank you so much for that.
Things learned last night.
1.  disabling high availabity SSO places all of the forward facing network ports in shutdown mode.
2.  you have to re-configure the network management port IP address manually
3.  debug transfer all enable is a handy command to run when you try to upload a cert.
11
