Community Member
Changing Group Names in ACS
I am working at a client site whom is running a fairly recent version of ACS.  They have some old group names under Network that they want to change to make their descriptions more valid.  Is it possible to change Network Device Group Names in ACS?  How about changing just "Group Names".
Kevin
1 ACCEPTED SOLUTION
Re: Changing Group Names in ACS
Hi Kevin,
It seems you are asking about ACS 4.x. IF that is the case then yes, we can change NDG name.
Editing a Network  Device Group
To edit an NDG, you must first access the  NDG. To do so, click the name of the NDG in the Network Device Groups table. Click Edit  Properties at the bottom of the page.
For changing individual aaa-client we need to delete and readd it.
~JG
DO rate helpful posts
1 REPLY
Hi Kevin,
~JG
202
