Changing the default management VLAN
I've been trying to change the management VLAN of my AP. Initially, I left everything as the default, which means that BVI1 is tied to the native VLAN. And the native VLAN is 1. My management VLAN was also VLAN1.
Cisco recommends changing the management VLAN of your devices to something other than 1. They also recommend using an unused VLAN for the native trunking VLAN. This means that the native and management VLANs have to be different and something other than 1.
How do I create a BVI that uses VLAN 200, without also changing the native VLAN to 200?
I've tried creating an ethernet subinterface fastethernet 0.200, and a BVI 200, but the device remains unreachable.
Silver
Re: Changing the default management VLAN
Management Vlan and Native Vlan need to be in Same vlan for access points and bridge. So the statement "Cisco recommends changing the management VLAN of your devices to something other than 1. They also recommend using an unused VLAN for the native trunking VLAN" dosnt mean different vlans for the interfaces.
Hi, I have the same requirement, I need to manage the AP through tagged packet, not the native vlan.
The AP trunked port should carry all the ssid operative vlan plus the AP management vlan.
thank you in advance
greatings
RS
Your config would look something like this. Remember to configure your switch interface as a trunk port.
interface Dot11Radio0.xxx
encapsulation dot1Q xxx native
no ip route-cache
bridge-group xxx
bridge-group xxx subscriber-loop-control
bridge-group xxx block-unknown-source
no bridge-group xxx source-learning
no bridge-group xxx unicast-flooding
bridge-group xxx spanning-disabled
no ip route-cache
bridge-group xxx
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
hold-queue 160 in
interface FastEthernet0.xxx
no ip route-cache
bridge-group xxx
interface FastEthernet0.108
no ip route-cache
bridge-group xxx
interface BVI1
ip address x.x.x.x x.x.x.x
no ip route-cache
Jake
834
