11-19-2008 08:53 AM - edited 07-03-2021 04:47 PM
Is there a way to change a port number for WCS that is already installed and running from say port 80 to port 82?
11-19-2008 09:42 AM
Are you running windows or Linux?
the apache conf files are buried under the WCS-X.x.x/ directory. For the ssl port under Linux, edit ssl.conf under /opt/WCS4.2.110.0/webnms/apache/ssl (or whatever your version is)
for port 80, edit httpd.conf under
/opt/WCS4.2.110.0/webnms/apache/conf
The files should be the same in either OS, but the locations are different
11-19-2008 09:49 AM
It is windows. I will give it shot. Thank you.
12-08-2008 11:32 PM
Easiest way is to take a backup. Then uninstall WCS, reinstall it and set the correct port during installation. Then perform a restore.
12-09-2008 06:43 AM
That seems like a lot of work compared to editing a conf file and restarting the service
12-09-2008 07:30 AM
That is the only supported way of changing HTTP port in versions 5.1 and below. Starting with v5.2, this setting is available under Administration --> Settings.
