Chipsets fail to assosiat with AP
wjgebe
I use the following config
dot11 ssid VU-Campusnet
vlan 104
authentication open eap Dot1x-Authentication
authentication key-management wpa optional
accounting Dot1x-Accounting
guest-mode
dot11 aaa csid ietf
dot11 network-map
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 104 key 3 size 128bit 7 xxx transmit-k
ey
encryption vlan 104 mode ciphers aes-ccm tkip wep128
encryption vlan 208 key 3 size 128bit 7 xxx transmit-k
ey
encryption vlan 208 mode ciphers aes-ccm tkip wep128
encryption vlan 802 key 3 size 128bit 7 xxx transmit-k
ey
encryption vlan 802 mode ciphers aes-ccm tkip wep128
encryption vlan 997 key 3 size 128bit 7 xxx transmit-k
ey
encryption vlan 997 mode ciphers aes-ccm tkip wep128
ssid VU-Campusnet
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2462
station-role root
rts threshold 2312
no dot11 extension aironet
no cdp enable
On the tested Wlan interface from Intel it works. But when we use the Sitecom WL170 or WL112 it won't. can some one help me...
Not applicable
Try disabling Aironet Extensions and check if it works. Aironet extensions are cisco proprietary and does not work with 3rd party clients. For more information on Aironet Extensions read http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_guide_chapter09186a0080606d4a.html#wp1135928
this is already done in the config
do you have a other idee
