Cisco 1130 - get @Mac of associated clients
Me again... I have an other issue...
I'm trying to receive the mac-address for all the
connected clients to a Cisco access-point (Cisco1130) by SNMP.
The best way to do this seems with the cDot11ClientConfigInfoTable
table.(CISCO-DOT11-ASSOCIATION-MIB OID: .1.3.6.1.4.1.9.9.273.1.2.1
The problem i have is that the mac-address of the clients isn't
readable. The permission for this OID is 'not-accessible'
(.1.3.6.1.4.1.9.9.273.1.2.1.1.1)
Does any know if there is a possibility to change this permission or
if there is another way to get the mac-address from
all the connected clients by SNMP(or in another way than SNMP)?
Thanks u by advance!
kka
Re: Cisco 1130 - get @Mac of associated clients
cDot11ClientAddress (1.3.6.1.4.1.9.9.273.1.2.1.1.1) is part of the index for
the cDot11ClientConfigInfoTable and therefore "not-accessible".
The last 6 octets of every OID in that table is the client MAC.
So you could walk cDot11ClientAid (Association ID) and get the following:
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID1"][0:30:f1:XX:XX:XX] = Gauge32: 222
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID1"][0:60:b3:XX:XX:XX] = Gauge32: 184
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID2"][0:e:35:XX:XX:XX] = Gauge32: 54
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID2"][0:12:17:XX:XX:XX] = Gauge32: 204
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID2"][0:12:f0:XX:XX:XX] = Gauge32: 252
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID2"][0:14:a5:XX:XX:XX] = Gauge32: 124
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID2"][0:14:bf:XX:XX:XX] = Gauge32: 151
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID2"][0:14:bf:XX:XX:XX] = Gauge32: 77
CISCO-DOT11-ASSOCIATION-MIB::cDot11ClientAid[1]["SSID2"][0:14:bf:XX:XX:XX] = Gauge32: 11
kka
Another possibility is "cd11IfAssignedSta" from the CISCO-DOT11-IF-MIB.
The cd11IfAssignedAidTable always contains rows for all possible AIDs
with a value of '00 00 00 00 00 00' for those with no associated client.
CISCO-DOT11-IF-MIB::cd11IfAssignedSta.1.11 = Hex: 00 14 BF XX XX XX
CISCO-DOT11-IF-MIB::cd11IfAssignedSta.1.20 = Hex: 00 12 17 XX XX XX
CISCO-DOT11-IF-MIB::cd11IfAssignedSta.1.151 = Hex: 00 14 BF XX XX XX
319
