Cisco 1140 AP - Cant enable 5GHz Radio on SSID after renaming
I'm sure i have missed something straight forward, I'm trying to enable 'Radio1-802.11n 5GHz' for the SSID 'xxx-public' on VLAN '666', but i am getting the error: VLAN '666' doesn't exist on 'Radio1-802.11N 5GHz (see Services> VLAN). I have checked in the GUI and 2.4 and 5GHz are both enabled on this VLAN.
It was enabled and working previously, all I have attempted to do is rename the SSID. I've tried renaming in the GUI and also deleting and recreating the SSID from the CLI.
Here is the config:-
version 12.4
no service pad
service password-encryption
hostname WAP02
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip domain name xxx.local
dot11 syslog
dot11 vlan-name UK2-GUEST vlan 666
dot11 vlan-name UK2-MGMT vlan 999
dot11 vlan-name UK2-WKS-WIFI vlan 31
dot11 ssid xxx-PUBLIC
   vlan 666
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 xxx
dot11 ssid xxx-PRIVATE
   vlan 31
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 xxx
crypto pki trustpoint TP-self-signed-2603134467
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2603134467
 revocation-check none
 rsakeypair TP-self-signed-2603134467
crypto pki certificate chain TP-self-signed-2603134467
 certificate self-signed 01
  xxxxx
  quit
username vpn privilege 15 secret 5 xx
username rancid privilege 15 secret 5 xx
username admin privilege 15 secret 5 xx
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers aes-ccm tkip
 encryption vlan 5 mode ciphers aes-ccm tkip
 encryption vlan 666 mode ciphers aes-ccm
 encryption vlan 31 mode ciphers aes-ccm
 ssid xxx-PUBLIC
 ssid xxx-PRIVATE
 antenna gain 0
 mbssid
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1
 no ip route-cache
 bridge-group 254
 bridge-group 254 block-unknown-source
 no bridge-group 254 source-learning
 no bridge-group 254 unicast-flooding
 bridge-group 254 spanning-disabled
interface Dot11Radio0.5
 encapsulation dot1Q 5
 no ip route-cache
 bridge-group 5
 bridge-group 5 subscriber-loop-control
 bridge-group 5 block-unknown-source
 no bridge-group 5 source-learning
 no bridge-group 5 unicast-flooding
 bridge-group 5 spanning-disabled
interface Dot11Radio0.31
 encapsulation dot1Q 31
 no ip route-cache
 bridge-group 31
 bridge-group 31 subscriber-loop-control
 bridge-group 31 block-unknown-source
 no bridge-group 31 source-learning
 no bridge-group 31 unicast-flooding
 bridge-group 31 spanning-disabled
interface Dot11Radio0.666
 encapsulation dot1Q 666
 no ip route-cache
 bridge-group 255
 bridge-group 255 subscriber-loop-control
 bridge-group 255 block-unknown-source
 no bridge-group 255 source-learning
 no bridge-group 255 unicast-flooding
 bridge-group 255 spanning-disabled
interface Dot11Radio0.999
 encapsulation dot1Q 999 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid xxx-PRIVATE
 antenna gain 0
 no dfs band block
 mbssid
 channel dfs
 station-role root
interface Dot11Radio1.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 254
 bridge-group 254 subscriber-loop-control
interface Dot11Radio1.5
 no ip route-cache
 bridge-group 5
interface Dot11Radio1.31
 no ip route-cache
 bridge-group 31
interface Dot11Radio1.666
 no ip route-cache
 bridge-group 255
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 254
interface GigabitEthernet0.5
 no ip route-cache
 bridge-group 5
interface GigabitEthernet0.31
 no ip route-cache
 bridge-group 31
interface GigabitEthernet0.666
 no ip route-cache
 bridge-group 255
interface GigabitEthernet0.999
 no ip route-cache
 bridge-group 1
interface BVI1
 ip address 10.9.40.142 255.255.255.128
 no ip route-cache
ip default-gateway 10.9.40.254
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
logging 10.9.32.250
snmp-server community xxx RO
snmp-server location xxx
snmp-server contact xxx
snmp-server chassis-id WAP02
bridge 1 route ip
line con 0
line vty 0 4
sntp server 10.9.40.20
end
1 ACCEPTED SOLUTION
VIP Purple
Hi,interface Dot11Radio1 no
 no ip address
 no ip route-cache
 ssid xxx-PRIVATE
ssid xxx-PUBLIC
add this command on radio1 interface via CLI, GUI is very slow in many cases.
VIP Purple
 no ip address
 no ip route-cache
 ssid xxx-PRIVATE
ssid xxx-PUBLIC
Many thanks Sandeep, missed
Many thanks Sandeep, missed that one and i was starting to pull my hair out..
VIP Purple
NO Problem Lan, something if
NO Problem Lan, something if you configure with GUI then it happens.that y i prefer CLI.
But I am glad that you finally resolved the problem.
Dont forget to rate helpful posts
835
