Cisco 1142AP Autonomous - Radio interface constantly reset and provides crash file
Hello All,
We have 10 Cisco 1142 Access Points currently configured as Autonomous and I'm experiecing very unusual behavior with the 2.4GHz radio interfaces on each of them. The IOS firmware is 15.2.2JB and they're connected to Cisco 2960 PoE switches. I'm not sure what could be causing this problem however it is service impacting and looks bad on me since I don't have a solution for it. One potential fix could be to upgrade the firmware to 15.2.4 but I'm sure if it is a firmware problem. Any advice would help. Here's an excerpt from the AP log:
Aug 18 14:40:16:  Writing driver stats to flash:/ap_log_r0_0.log..
Aug 18 14:40:21:
Aug 18 14:40:21: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
Aug 18 14:40:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
Aug 18 14:40:23: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
Aug 18 14:40:23: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Ali Ibrahim
1 ACCEPTED SOLUTION
You should be able to go in
You should be able to go in and view teh R0_0.log file.
there might be something in there that you can do a bug search for.
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Thanks for your reply Steve.
The .log file is not human-readable.
Ali.
39
