Cisco 1200 Aironet Access point and MAC Auth.
I am trying to use WEP and MAC auth for my access point. The WEP side works fine but when I enter a MAC address and set it to allow that works and any other wireless NIC I plug into my machine. Can anyone tell me what I am missing so only the correct WEP and only Allowed MAC's will be able to access the acess point.
Thanks, Dan
1 REPLY
Re: Cisco 1200 Aironet Access point and MAC Auth.
Sounds like you config is not right but really hard to say given the info you have here
Make sure you configure exactly as per this
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/ap120scg/bkscgc8.htm#1031298
If you are not running leap and mac then is mac alone enough to be fully authenticated should be set to 'no' this is the most common mistake people make
618
