Cisco 1552E AP Not Joining WLC
Need help with an AP (Cisco1552E) that I just brought online today. Somehow it can't seem to joing the WLC 2500.
debug on WLC gives the result below:
debug capwap errors
*spamApTask7: Apr 25 17:18:20.098: 68:86:a7:29:91:00 ApModel: AIR-CAP1552E-N-K99
*spamApTask7: Apr 25 17:18:20.098: Could not find image version of bundled AP(apType: 20)!!!
*spamApTask7: Apr 25 17:18:20.098: Unable to get AP Bundled Version. Using Controller Version!!!
Could be IOS version mismatch ....
Anyway if anyone has come across this issue. would really appreciate any help..
Waisiki
Hall of Fame Super Gold
Your WLC should be running a
Your WLC should be running a minimum firmware of 7.0.116.X.
Configuring MAC Filtering
For a mesh access point to connect to a Cisco wireless LAN controller, you need to add the access point to the controller's MAC filtering list.
To add the access point to a controller's MAC filtering list, do one of the following:
In the Web user interface of the controller, choose the MAC filtering option (Security > AAA > MAC Filtering) and manually add the mesh access points.
In Cisco WCS, go to the MAC filtering template (Configure > Templates > Security > MAC Filtering); create a list of bridging mesh access points, and send them to multiple Cisco wireless LAN controllers.
I'm currently running
I'm currently running software version 7.6.100.0.
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.100.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
As for the MAC Filtering, I've already entered the MAC address of this AP.
Still getting this error.
Waisiki
Post the complete output to
Post the complete output to the WLC command "sh sysinfo".  I want to see the first page only.
Also post output to the AP command "sh version".
sh sysinfoMAP-8-Hall-68:86:A7
sh sysinfo
MAP-8-Hall-68:86:A7:29:99:00#show version
Cisco IOS Software, C1550 Software (C1520-K9W8-M), Version 15.2(4)JB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 06-Mar-14 12:04 by prod_rel_team
ROM: Bootstrap program is C1550 boot loader
BOOTLDR: C1550 Boot Loader (C1520-BOOT-M) LoaderVersion 15.2(2a)JA, RELEASE SOFTWARE (fc1)
MAP-8-Hall-68:86:A7:29:99:00 uptime is 2 hours, 6 minutes
System returned to ROM by power loss
System image file is "flash:/c1520-k9w8-mx.152-4.JB4/c1520-k9w8-xx.152-4.JB4"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1552E-N-K9 (PowerPC 8349) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1652P090
PowerPC 8349 CPU at 533MHz, revision number 0x0031
Last reset from power loss
LWAPP image version 7.6.100.0
AVR Microcontroller 2 - SW Version: 00.01.09
AVR Microcontroller 6 - SW Version: 00.01.00
4 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 68:86:A7:29:99:00
Part Number                          : 73-13538-02
PCA Assembly Number                  : 800-31224-01
PCA Revision Number                  : 03
PCB Serial Number                    : FOC165024VH
Top Assembly Part Number             : 800-34851-04
Top Assembly Serial Number           : FTX1652P090
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1552E-N-K9
Configuration register is 0xF
sh version
Last reload reason:
export@cisco.com.
2 802.11 Radios
Hi everyone,finally got it
Hi everyone,
finally got it right and resolved. Funny enough the problem seems to be the old version of the Cisco Lightweight IOS on the AP's. I logged in to each AP and manually pushed the new images via TFTP.
Once the AP's had rebooted and we on their new images, their operations become a whole lot more stable - Please note that this had nothing to do with the Cisco WLC after all.
Edwin
I believe I"m having the same
I believe I"m having the same problem. We upgraded from 7.6 to 8.1 and now the air-cap3702e-e-k9 is disconnecting after couple of minutes. What did you mean by manually pushed the new images via TFTP. I'm assuming you went on the lwap and did it?
905
