Cisco 1941w ISR bridge
Hi everyone, here is the scenario. We have been deploying Cisco 1941w ISRs at our office locations. We love this guy due to the built-in AP which doesn't require us to purchase a separate Access Point for each location. However this is also causing us to use 2 subnets per office, one for wired LAN and other for wireless LAN. Below is my interface configuration;
GigabitEthernet0/0 ....... xxx.xxx.xxx.xxx External
GigabitEthernet0/1 ....... 172.18.24.1 /24    Internal     FIRST SUBNET
wlan-ap0 ............ ip unnumbered VLAN1
VLAN1 - 172.18.124.1 /24                 SECOND SUBNET
VLAN900 - 10.18.24.1 /24
VLAN900 is only for use by guests and not advertised out of this office. We have 2 SSIDs, one for corporate and another for guests
AP configuration:
Interface BVI1 ............. 172.18.124.250
Default-gateway............ 172.18.124.1
SSID_Corp - Vlan1
SSID_Guest - Vlan900
We have an AD based DHCP server which serves IPs to all wired devices in the 172.18.24.0 network.
We have a DHCP pool on the AP itself that serves IPs to all wireless devices in the 172.18.124.0 network.
You may ask, why do we have 2 separate subnets. Well, thats the reason I came knocking on your doors. Is there a way to configure the built-in AP as a bridge and not an Access Point. I want that any wireless device that authenticates with the bridge, obtains an IP address from the AD i.e. 172.18.24.0 network on VLAN1.
But at the same time, I also want it to continue acting as an Access Point for SSID_Guest so that our guests can access the internet through it over vlan 900?
I know I'm asking for too much but I am a bit new to this and not sure how or if this can be done.
Please advise.
1 ACCEPTED SOLUTION
ok, so what you can do is this:
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
int g0/1
no ip address
bridge-group 1
int vlan 1
bridge-group 1
interface BVI 1
ip address 172.18.150.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
That will allow you to have the LAN and the AP be on the same subnet.  You already have teh WLAN-Gig0/0 in the correct state.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Anybody?
Yes, what you are looking to do is possible.  Basically you would need to configure a second SSID and call the VLAN in both, then on the interface Wlan-GigabitEthernet0/0 change it to a trunk port.
As a short example.  This is assuming you are using a WPA/TKIP with a PSK for the 'corp'
SSID Configs:
dot11 ssid SSID_Corp
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 0 12345678
dot11 ssid SSID_Guest
vlan 900
authentitcation open
guest-mode
Sub-Interface Configs
interface dot11radio0.1
encapsulation dot1q 1 native
interface dot11radio1.1
interface dot11radio0.900
encapsulation dot1q 900
bridge-group 2
interface dot11radio1.900
interface G0.1
interface G0.900
encapuslation dot1q 900
Radio Configs
Interface dot11radio0
encryption vlan 1 mode ciphers tkip
ssid SSID_Corp
ssid SSID_Guest
Interface dot11radio1
ssid SSID_Corp
ssid SSID_Guest
then on the router
switchport mode trunk
Hope this helps,
Steve
Hi Steve, thanks for the advice. The problem is that vlan1 and gigabit0/1 can't have the same IP address. And when I configure the same IP on VLAN1 using the ip unnumbered gigabitethernet0/1 command, I am no longer able to ping the .1 IP address from the AP because of which it can't see it's VLAN gateway. Looks like only solution is to have a separate subnet
Re: Cisco 1941w ISR bridge
No it can be done. Can you post the config if the router and the AP?
Here you go. Please note that I haven't configured anything on the AP other than an IP address on the BVI1 interface and default-gateway.
ROUTER CONFIG
hostname r-lab-1
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.152-2.T.bin
boot-end-marker
enable secret 5 ommitted
no aaa new-model
clock timezone EST -5 0
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 172.18.150.1
ip dhcp excluded-address 172.18.150.250
ip dhcp pool LAN
network 172.18.150.0 255.255.255.0
default-router 172.18.150.1
dns-server 172.18.120.10 172.18.120.12
lease 7
redundancy
controller Cellular 0/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address ommitted
ip nat outside
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description LAN
ip nat inside
duplex auto
speed auto
description Internal switch interface connecting to the embedded AP
no ip address
interface Vlan1
ip unnumbered GigabitEthernet0/1
AP CONFIG
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$Tgpy$8JqkCx0YOxfOc1zsTnLdw/
no aaa new-model
dot11 syslog
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
description  the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 172.18.150.250 255.255.255.0
no ip route-cache
ip default-gateway 172.18.150.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
no activation-character
line vty 0 4
login local
bridge irb
bridge 1 route ip
int g0/1
no ip address
bridge-group 1
int vlan 1
bridge-group 1
interface BVI 1
ip nat inside
Steve
Hi Stephen, I want to thank you for helping me out with this problem. It is now working flawlessly. I had to do some minor modifications but everything is working now. I have two separate DHCP pools on the router, one for corp and the other for guest and are both serving IPs on the corresponding SSID. Also when I connect with a wired connection, I am getting IP from the same DHCP pool as SSID Corp. This saves us an entire subnet space for an office where we only have 50 users.
Thanks once again! You have no idea how long we have been working on this. Even spoke with CCIE who said that this can't be done.
You Rock Sir!
Cheers!
Two years later and I find
Two years later and I find myself looking for the exact same solution.
Can someone tell me if the solution above was applied to the Router or AP?
Yes this has been working
Yes this has been working without any issues for 2 years. I have deployed this at various locations.
1019
