Cisco ACS 3.0 EAP-TLS
Did anybody here use EAP-TLS authentication for Wireless NICs from other vendors?
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350cards/windows/incfg/win_appe.htm
This link talks about how to configure dynamic key encryption for generic 802.1x that comes with Windows XP. But conerns are
1> Can we support mixed wireless NICs, say we have some users using Cisco NICs with LEAP, and some users using Compaq NICs on XP machine using EAP-TLS. What changes do we need to do on ACS and AP in order to provide this support?
2> Do 802.1x from XP and LEAP from Cisco provide the same level of security or LEAP is more secure?
Thanks.
  • Security and Network Management
Re: Cisco ACS 3.0 EAP-TLS
It’s my understanding that Cisco LEAP is more robust from a security standpoint. I don’t believe you can pick and choose. If your environment has non-Cisco nics as well, you’ll have to abandon LEAP support for now and just use EAP. Am I wrong? Anyone out there know for sure? If so, I can’t find a config example anywhere.
I don't think there's any problem interoperating between LEAP and EAP. Configuration for EAP-TLS is avaliable in CCO.
136
