Cisco ACS and eee pc
hello
we have an LWAPP wireless network using Cisco WiSMs and a 4404 controller. our main SSID uses WPA 802.1x and users are authenticated by a Cisco ACS 4.0 - the ACS has a valid 3rd party cert installed. i've tested PEAP successfuly with a number of OS's.
i'm trying to get an Asus eee pc working with this SSID - there are a lot of guides on the web on how to achieve this but i'm having problems getting the eee pc to authenticate with the ACS.
i get the following in the Failed Attempts log (i've tried installing the ACS Root and intermediate certs on the eee pc)
EAP-TLS or PEAP authentication failed during SSL handshake
in the CSAUTH logs i get:
AUTH 12/11/2008 16:20:17 E 0143 3696 [PDE]: PdeAttributeSet::addAttribute: invalid attr type=200
AUTH 12/11/2008 16:20:17 E 0143 3696 [PDE]: PdeAttributeSet::addAttribute: invalid attr type=201
can anyone explain the entries in the CSAUTH log?
thanks
andy
Bronze
Re: Cisco ACS and eee pc
Restart CSAuth.exe service, and then try to authenticate again (with
Machine credentials)
For the Logs and Reports for the ACS following URl will help you
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.0/user/guide/r.html#wp550449
thanks for the reply - problem was with the eee pc. a colleague was working on the eee pc before i got it. reset the eee pc to factory defaults and followed the instructions at
http://lug.wsu.edu/wireless/peap/eee
after that the eee pc worked ok.
cheers
andy
379
