Cisco ACS (TACACS+) - AAA failure on WLC
Setting up TACACS+ between Cisco ACS and 4402 WLC using the below configuration guide.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080851f7c.shtml#add-authorizserv
Authenication is failing on the WLC. Currently getting the below error message on the Cisco ACS server (Reports and activity > failed attempts)
Message Type: Author Failed
Author-Failure-Code: Service denied
Author-Data: service=ciscowlc protocol=common
Anybody have any idea to resolve this problem.
Colm
Re: Cisco ACS (TACACS+) - AAA failure on WLC
The document you referred is correct.
What version of WLC are you running?
Check this one:
CSCsk21007    WLC requires tacacs authentication when configuration change ccess Control
JK
Plz rate helpful posts-
~BR Jatin Katyal **Do rate helpful posts**
WLC is running v6.0.188.0
Could I be missing a TACACS+ value on the Cisco ACS.
2197
