Community Member
cisco air cap1602e e k9 not working with the wlan controller 2504-k9
Hi ,
we have some new cisco air cap1602e e k9 access points and they are not working with the wlan controller 2504-k9.
the controller is running ios Software Version 7.2.115.1 .looking at various blogs they  to upgrade our ios version but am wondering how to go about it .can you just upgrade to latest or is there a way to upgrade.
Below are the error messages from the AP.
*Mar  1 01:09:30.333: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 01:09:33.345: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 01:09:33.409: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.30.102.29, mask 255.255.255.0, hostname APfc99.47a3.7b4f
*Mar  1 01:09:41.333: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'Cisco_31:ba:44'running version 7.2.115.1 is rejected.
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 01:09:51.337: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.30.195.2
2 ACCEPTED SOLUTIONS
Hall of Fame Super Blue
Post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
According to the error message you've posted, the WLC does NOT have the correct time and date settings.
Product Version..............
Product Version.................................. 7.2.115.1
This is the firmware of your WLC.  Take note the version number.
Product/Model Number                 : AIR-CAP1602E-E-K9
This is your AP model number.
Go HERE.  Scroll down and you'll see that if you want to use 1600 then you'll need to upgrade the firmware of your WLC to 7.4.100.X.
NOTE:  I would recommend you upgrade the firmware of your WLC to 7.4.121.0.
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
Community Member
Hi,Attached is the output of
Attached is the output of the show commands as requested.
kindly get back to me as soon as possible if you require anything to help in this matter.
If i was to upgrade the IOS of the WLAN Controller, in what order of IOS image would i begin with.? or do i just upgrade to the latest and would it affect the wireless network?
Community Member
Hi Leo,thanks for the
Hi Leo,
thanks for the feedback. one question though ,should we expect a down time while doing this upgrade and how do we prevent the downtime. Also how can we upgrade to the latest ios 7.6.120.0 and how can we do it.
thanks
Yes.  It takes about 25 to 40 minutes to upgrade the firmware.
Read THIS.
NOTE:  Please do not forget to upgrade the FUS code too.  Read THIS.
Community Member
thanks .i upgraded the wlan
thanks .
i upgraded the wlan controller and the AP'S worked okay.
Glad to hear everything is
Glad to hear everything is working fine.
Community Member
your WLC don't have correct
your WLC don't have correct time and date settings.
More information about cisco air cap1602e e k9 , wish it can help you.
374
