Cisco Aironet 702 - Transmitter Power: error
hi,
  I have problem with setup Cisco Aironet 702. I set all properties. Interfaces gigaEthernet and Radio0 are UP. I don't see my SSID in network. On properties for Radio0 I see error in section Transmitter Power. How can I troubleshooting this issue?
Here I uploaded screens from configuration pages
https://onedrive.live.com/?gologin=1&mkt=en-US#cid=0AE7867F90F4DB32&id=AE7867F90F4DB32!257
regards,
Jacek
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cisco Aironet 702 - Transmitter Power: error
If you want to see the SSID being broadcasted you need to use guest-mode
dot11 Your-SSID
guest-mode
If you have multiple SSIDs and want both broadcasted you add mbssid
dot11 Your-SSID
mbssid guest-mode
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4_10b_JA/configuration/guide/scg12410b/scg12410b-chap7-mbssid.html
-Scott
can you post the show run from the AP?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
running config
Current configuration : 1838 bytes
! Last configuration change at 01:23:01 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname apOpenSpace
logging rate-limit console 9
enable secret 5 $1$AL/C$ZkBchBuZ9hGtztdUacBmO/
no aaa new-model
no ip cef
dot11 syslog
dot11 ssid Artim_Wifi
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 096D5C1D1008464B525C
dot11 guest
username Cisco password 7 096F471A1A0A
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
ssid Artim_Wifi
antenna gain 0
power local 5
packet retries 64 drop-packet
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
antenna gain 0
peakdetect
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
ip address 10.6.11.54 255.255.255.0
duplex auto
speed auto
bridge-group 1
interface BVI1
ipv6 address dhcp
ipv6 address autoconfig
ip default-gateway 10.6.11.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
VIP Purple
dot11 Your-SSID
guest-mode
dot11 Your-SSID
mbssid guest-mode
-Scott
Here is a better and easier link to follow
http://mrncciew.com/2012/10/24/multiple-ssid-config-on-autonomous-ap/
http://jenniferhuber.blogspot.com/2009/12/how-to-broadcast-multiple-ssids-on.html?m=1
-Scott
433
