cisco ap 700 problem WPA
salah gobbaa
we have a problem on cisco ap 700,i configure an ssid without password ,security open i don't have any problem but when i put the password to ssid,i didn't conncet to the ssid
Saurav Lodh
Level 7
Level 7
Problem can be with Client side also. What security standard you are using? Have you tried to connect different type of clients?
hi salodh,
thank you, it is ok the problem is solved:
it is the type of password "preshared key"
