Community Member
cisco ap 700 problem WPA
we have a problem on cisco ap 700,i configure an ssid without password ,security open i don't have any problem but when i put the password to ssid,i didn't conncet to the ssid
Problem can be with Client
Problem can be with Client side also. What security standard you are using? Have you tried to connect different type of clients?
Community Member
hi salodh,thank you, it is ok
hi salodh,
thank you, it is ok the problem is solved:
it is the type of password "preshared key"
76
