Cisco AP: Logging onto wireless with LDAP credentials
j4ckripp3r
I have 2 cisco 1141 aironets access points.
I've fallowed this tutorial:
http://evilrouters.net/2008/11/19/configuring-freeradius-to-support-cisco-aaa-clients/
I have an ubuntu server running freeradius authenticating against an LDAP server.
Now I'm able to log into the AP via ssh with my LDAP credentials.
What I can't figure out is how do I setup the AP so when people connect to the AP's wireless they are prompted to use their LDAP credentials.
I've gone through a bunch of different articles online and I feel that I'm just confusing myself even more.
7 Replies 7
Stephen Rodriguez
Can you post the config of the AP?  I'd like to see where you are currently at.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thank you for the help.
Here is the config
version 12.4
no service pad
service password-encryption
hostname cldap2
enable secret 5
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius if-authenticated
aaa accounting exec default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
ip domain name something.net
dot11 syslog
dot11 vlan-name inside vlan 2
dot11 vlan-name test2 vlan 22
dot11 ssid WiFi
   vlan 22
   authentication open
   authentication key-management wpa optional
   mbssid guest-mode
   wpa-psk ascii 7
dot11 ssid inside
   vlan 2
   authentication open
   authentication shared
   mbssid guest-mode
crypto pki trustpoint TP-self-signed-1224361256
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1224361256
revocation-check none
rsakeypair TP-self-signed-1224361256
crypto pki certificate chain TP-self-signed-1224361256
certificate self-signed 01
  quit
ip ssh logging events
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
encryption vlan 22 key 2 size 128bit 7 transmit-key
encryption vlan 22 mode ciphers aes-ccm tkip wep128
broadcast-key vlan 22 change 60
ssid WiFi
ssid inside
antenna gain 0
mbssid
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
infrastructure-client
interface Dot11Radio0.2
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.22
encapsulation dot1Q 22
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex full
speed auto
no keepalive
interface GigabitEthernet0.2
no ip route-cache
bridge-group 1
interface GigabitEthernet0.22
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.12.20.124 255.255.255.0
no ip route-cache
ip default-gateway 10.12.0.2
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
access-list 111 permit tcp any any neq telnet
snmp-server community
snmp-server location Solana Beach, California, USA
snmp-server contact
snmp-server enable traps snmp authentication linkdown linkup coldstart
snmp-server host 10.12.10.3
radius-server host 10.12.10.3 auth-port 1812 acct-port 1813 key 7
bridge 1 route ip
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
sntp server 10.12.10.3
end
Ok, so pasting this into your AP should work
conf t
aaa group server radius rad_eap
server 10.12.10.3 auth-port 1812 acct-port 1813
exit
Dott11radio0
encryption vlan 2 mode ciphers aes-ccm
exit
dot11 ssid inside
vlan 2
no authentication shared
authentication open eap rad_eap
authentication key-management wpa version 2
exit
So I'll explain:
This configures the AP to use a server group, and in the config this server group is referred to as 'rad_eap'.  If you need to add more servers for user authenticaion, you just need to go under the group and add more servers.
Dot11radio0
This tells the radio, that for vlan two, we are going to use the cipher suite of aes.  If your clients do not support WPA 2, change this to encryption vlan 2 mode ciphers tkip.
dot11 ssid inside
vlan 2
Now this is where we tell the SSID, how we are going to work with the client.  You shouldn't need authentication shared, for EAP.  Really shouldn't need it for a PSK either, most clients will work with just authentication open.
the authentication open line, tells the AP that we are using an open authentication, that we are expecting EAP requests from the client, and what server group it should send the AAA requests to.
Finally, we are telling the SSID that we only want clients that can do WPA 2.  If your clients do not support WPA 2, then change this line to be authentication key-management wpa
This should get you working with using EAP for your clients.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
I made those changes and I had freeradius in debug mode. When I started authentication on ssid Mike I would get a login box for username/passwod but when authentication starts freeradius isn't getting any request but when I ssh into the AP I get a request.
Sorry, I forgot to mention I'm using the ssid Mike.
Thanks again for your help.
Here is my config after the changes:
version 12.4
no service pad
hostname cldap2
enable secret 5
aaa new-model
ip domain name onerecovery.net
dot11 syslog
dot11 ssid Mike
   vlan 22
   mbssid guest-mode
  quit
username Cisco privilege 15 password
bridge irb
no ip address
no ip route-cache
ssid Mike
antenna gain 0
mbssid
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 2
no ip address
no ip route-cache
duplex full
speed auto
no keepalive
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 2
interface BVI1
no ip route-cache
no ip http server
snmp-server community ORVjkPtki8q RO
snmp-server contact OneRecovery NOC -
bridge 1 route ip
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
end
gah!  silly cut and paste.  It missed one of the commands:
radius-server attribute 32 include-in-access-req format %i
This tells the AP to send it's IP address to be processed by the AAA.
HTH,
Steve
I added:
I'm still getting the same results. The freeradius server isn't getting any request from the AP when a user joins the ssid Mike.
Double checked that document you posted.  That only goes over the config for using freeRADIUS as an authenticator for device management login.
Take a look at the link below that coves configuring freeRADIUS for PEAP.
http://tldp.org/HOWTO/8021X-HOWTO/freeradius.html
HTH,
Steve
