Cisco AP1142N won't join controller
When upgrading one of our WISM controller cards a problem occurred with some AP1142N.
The can’t join controller with 7.6.120.0, upgrading was from 7.4.121.0
When CLI into the AP I got this messages:
  1. Reboot and tries to connect to the WISM2 with  7.6.120.0, but it fails.
  2. Then tries to connect to another WISM2 with 7.4.121.0 and this work
  3. But then the image on the AP is not correct (have a 7.6.120.0 image)
  4. Downgrading AP to 7.4.121.0 image
  5. Reboot and are back to number 1.
*Mar  1 00:01:09.564: %CAPWAP-3-ERRORLOG: Selected MWAR 'JKP-WISM-02-I '(index 0).
*Mar  1 00:01:09.564: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Sep 10 11:25:00.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.17.16.25 peer_port: 5246
*Sep 10 11:25:29.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2176 Max retransmission count reached!
Translating "CISCO-CAPWAP-CONTROLLER.net.yyyy.se"...domain server (xxx.xxx.xxx.xxx) [OK]
*Mar  1 00:00:59.550: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Sep 10 11:25:59.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.17.16.25:5246
*Sep 10 11:26:00.000: %CAPWAP-3-ERRORLOG: Selected MWAR 'JKP-WISM-02-I (index 0).
*Sep 10 11:26:00.000: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Sep 10 11:25:30.000: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2176 Max retransmission count reached!
examining image...
extracting info (292 bytes)
Image info:
    Version Suffix: k9w8-.124-23c.JA8
    Image Name: c1140-k9w8-mx.124-23c.JA8
    Version Directory: c1140-k9w8-mx.124-23c.JA8
    Ios Image Size: 4915712
    Total Image Size: 5110272
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: C1140
    Wireless Switch Management Version: 7.0.250.0
Extracting files...
c1140-k9w8-mx.124-23c.JA8/ (directory) 0 (bytes)
extracting c1140-k9w8-mx.124-23c.JA8/T5.bin (23836 bytes)
*Sep 10 11
extracting c1140-k9w8-mx.124-23c.JA8/8001.img (174932 bytes):25:59.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.17.16.25:5246
Everyone's tags (1)
Hall of Fame Super Gold
Power down the AP for about
Power down the AP for about ten seconds and power it back up.  See if this fixes it.
With a WISM, you have by
With a WISM, you have by definition an etherchannel between your controller & APs.  Try setting the load balancing algorithm on the switch housing the WISM to src-dst-mac before connecting the AP.  There is/was an issue that shows itself rarely where other load balancing mechanisms interfere with an AP's initial join to a controller.  The problem declined significantly over the years, but you may be running into it.
Once the AP joins, you can reset your load balancing and you shouldn't have the problem even if the AP reboots later.  It usually impacts APs that have never joined your controller.  Don't know why.  Since this was an upgrade it may not be your problem, but it won't hurt to try.
I have located the problem to
I have located the problem to bug QSCuh46442.
159
