Cisco APs not updating after WLC-update
Hello everyone,
I need to update my 5508 WLCs to a newer software, to support new AP-models.
Started with AIR-CT5500-K9-1-7-0-0-FUS.aes and AIR-CT5500-K9-7-0-240-0.aes, everything worked fine. Pre-Downloaded the newer Image to the APs, restarted the WLCs and everything was ok.
Now I tried to update to 7.6.100.0 as well as 7.4.121.0. Both Versions should support my APs, but it doesn't work at all.
Any ideas are highly appreciated.
If you need further output, just let me know.
Manuel
These are some informations about the environment, AP-info and logging after "upgrade" to 7.4.121.0, controller-information after downgrading again...
AP#  sh ver
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.4(23c)JA7, RELEASE SOFTWARE (fc1)
ROM: Bootstrap program is C1240 boot loader BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
AP uptime is 1 minute System returned to ROM by power-on System image file is "flash:/c1240-k9w8-mx.124-23c.JA7/c1240-k9w8-mx.124-23c.JA7"
cisco AIR-LAP1242AG-E-K9  (PowerPCElvis) processor (revision A0) with 27638K/5120K bytes of memory.
Processor board ID FCZ1545812F
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on LWAPP image version 7.0.240.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 70:CA:9B:07:86:B8
Part Number                          : 73-10256-07
PCA Assembly Number                  : 800-26918-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15402NP4
Top Assembly Part Number            : 800-29152-03
Top Assembly Serial Number          : FCZ1545812F
Top Revision Number                  : A0
Product/Model Number                : AIR-LAP1242AG-E-K9
Configuration register is 0xF
AP#dir
Directory of flash:/
2  -rwx      89311  Jan 18 2014 20:41:00 +00:00  event.log
3  drwx          64  Jan 18 2014 20:43:21 +00:00  update
5  drwx        256  Jan 18 2014 20:40:55 +00:00  c1240-k9w8-mx.124-23c.JA7
4  -rwx        6168  Nov 2 2011 23:32:18 +00:00  private-multiple-fs
7  -rwx        395  Mar 1 2002 00:00:05 +00:00  env_vars
15740928 bytes total (8772096 bytes free)
AP#dir
Directory of flash:/c1240-k9w8-mx.124-23c.JA7/
9  -rwx      131328  Jan 18 2014 20:39:46 +00:00  7101.img
10  -rwx        292  Jan 18 2014 20:39:46 +00:00  info
11  -rwx    4642714  Jan 18 2014 20:40:55 +00:00  c1240-k9w8-mx.124-23c.JA7
15  -rwx      131328  Jan 18 2014 20:40:56 +00:00  6701.img
#sh logging --> see attached file
CONTROLLER (unfortunately after downgrading it again):
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.240.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.112.21
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... WLC-IP
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 26 mins 3 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna Current Boot
License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... DE  - Germany
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 5
Burned-in MAC Address............................ 1C:DF:0F:C6:D8:80
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 150
(Cisco Controller) >show boot
Primary Boot Image............................... 7.4.121.0
Backup Boot Image................................ 7.0.240.0 (default) (active)
(Cisco Controller) >show ap bundle primary
Primary AP Image        Size
ap1g2                  9576
ap3g1                  6684
ap3g2                  11208
ap801                  5192
ap802                  5232
c1100                  3096
c1130                  4972
c1140                  4992
c1200                  3364
c1240                  4812
c1250                  5512
c1310                  3136
c1520                  6412
c3201                  4324
c602i                  3716
(Cisco Controller) >show ap bundle secondary
Secondary AP Image      Size
ap3g1                  6684
ap801                  5192
ap802                  5232
c1100                  3096
c1130                  4972
c1140                  4992
c1200                  3364
c1240                  4812
c1250                  5512
c1310                  3136
c1520                  6412
c3201                  4324
c602i                  3716
Nachricht geändert durch Manuel Sporleder
-- Regards, Manuel
Hall of Fame Super Gold
Predownload on the 1240 won't work because the 1240 doesn't have enough flash memory to store two IOS.
I run 7.6.100.0 and I have several 1240.  Your 1240 will still work with 7.6.100.0, however, it is not clear whether 1130/1240 will work when 8.0 gets out.
VIP Purple
Agree with Leo
I don't think you can pre download to those older APs due to the memory.
Guidelines and Limitations for Predownloading Images
Follow these guidelines when you use image predownloading:
  • The maximum number of concurrent predownloads is limited to half the number of concurrent normal image downloads. This limitation allows new access points to join the controller during image downloading.
  • If you reach the predownload limit, then the access points that cannot get an image sleep for a time between 180 to 600 seconds and then reattempt the predownload.
  • Before you enter the predownload command, you should change the active controller boot image to the backup image. This step ensures that if the controller reboots for some reason, it comes back up with the earlier running image, not the partially downloaded upgrade image.
  • Access points with 16-MB total available memory (1130 and 1240 access points) may not have enough free memory to download an upgrade image and may automatically delete crash info files, radio files, and any backup images to free up space. However, this limitation does not affect the predownload process because the predownload image replaces any backup image on the access point.
Hope it helps.
Dont forget to rate helpful posts
thank you very much for your replies.
ok, maybe pre-downloading does'nt work, even if I don't understand why the controllers report everything is fine...
but: if I restart the controllers with a newer version than 7.0.240.0 without pre-downloading that version to the accesspoints before, they just download the newer version, and after they try to join the controller again, they report that the version on the controller is different ant try the update again and again and again... :-/
-- Regards, Manuel
that 4th point is exactly what I see on the accesspoints if I take a look at the directory of the APs IOS itself.
but it doesn't explain why predownloading shouldn't work. I think it is working...
-- Regards, Manuel
VIP Purple
1st upgrade WLC to 7.4 and theny try to connect AP.
Here u will have Active: 7.4
Backup: 7.0.240
Paste the logs
2nd  then Upgrade to 7.6 and then again try to connect AP.
Here u will have Active: 7.6
Backup: 7.4
After upgrade to 7.4 or 7.6, what logs u see on console of AP.
Can you paste that ??
Reagrds
Hey Sandeep,
I'll do this and post the logfiles.
Since I have to work with a highly productive environment I'll have to wait to get a time-slot this night for rebooting the controllers.
Regards, Manuel
-- Regards, Manuel
Hall of Fame Super Silver
Re: Cisco APs not updating after WLC-update
The 1240's will not download the image since it doesn't have enough memory to handle multiple images on flash. When you upgrade the WLC code and reboot the WLC, the AP's will rejoin the WLC and the WLC will push the correct image to the access points. The catch here is that you need to make sure you have enough flash memory available. I have went through each AP's and deleted event logs and crash files and RCV images prior to rebooting the WLC. I have also not done that and just rebooted the WLC and then visit AP's that failed to come back up. Many time it was due to the flash being full and not enough memory.
-Scott
Hello Scott,
what should I delete?
This is everything that ist stored in the flash:
2  -rwx      89476  Jan 20 2014 20:37:36 +00:00  event.log
6  drwx        256  Jan 20 2014 20:37:31 +00:00  c1240-k9w8-mx.124-23c.JA7
4  -rwx        6168  Jan 20 2014 20:42:28 +00:00  private-multiple-fs
5  -rwx        395  Jan 20 2014 20:42:27 +00:00  env_vars
15740928 bytes total (10736128 bytes free)
9  -rwx      131328  Jan 20 2014 20:36:22 +00:00  7101.img
10  -rwx        292  Jan 20 2014 20:36:22 +00:00  info
11  -rwx    4642714  Jan 20 2014 20:37:31 +00:00  c1240-k9w8-mx.124-23c.JA7
15  -rwx      131328  Jan 20 2014 20:37:32 +00:00  6701.img
Regards, Manuel
-- Regards, Manuel
The event log is the only thing you can delete. There is only 16mb of flash memory and there isn't enough memory to store another image. If you reload the WLC with the new code, these AP's will or should I say should join and download the image. Pre-download will not work. Is that what your trying?
-Scott
Hi Scott,
I am not trying to pre-download it anymore, since this doesn't work at all.
If I just restart the controller, the APs are downloading the image telling me "everything is fine", are rebooted and that stated with the old image again.
This is what you can see in the attached log-file:
*Mar  1 00:00:05.873: soap_prepare_new_image_crash: mini ios flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx
*Mar  1 00:00:06.242: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.662: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.054: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:09.152: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:09.181:  status of voice_diag_test from WLC is false
*Mar  1 00:00:11.381: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:11.440: %SYS-5-RESTART: System restarted
*Mar  1 00:00:11.441: %SNMP-5-COLDSTART: SNMP agent on host AP is undergoing a cold start
*Nov  2 23:31:59.107: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov  2 23:31:59.108: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  2 23:31:59.929: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Nov  2 23:32:00.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Nov  2 23:32:00.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Nov  2 23:32:18.102: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov  2 23:32:18.163: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Nov  2 23:32:18.345: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Nov  2 23:32:18.759:  status of voice_diag_test from WLC is false
*Nov  2 23:32:18.847: Logging LWAPP message to 255.255.255.255.
*Nov  2 23:32:33.181: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Nov  2 23:32:33.247: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  2 23:32:34.212: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov  2 23:32:34.213: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Jan 20 20:32:44.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: WLC-1-IP peer_port: 5246
*Jan 20 20:32:44.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 20 20:32:45.479: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: WLC-1-IP peer_port: 5246
*Jan 20 20:32:45.480: %CAPWAP-5-SENDJOIN: sending Join Request to WLC-1-IP
*Jan 20 20:32:45.481: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jan 20 20:32:45.483: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jan 20 20:32:45.483: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jan 20 20:32:45.483: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jan 20 20:32:45.484: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from WLC-1-IPperform archive download capwap:/c1240 tar file
*Jan 20 20:32:45.494: %CAPWAP-5-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*Jan 20 20:32:45.499: %CAPWAP-5-CHANGED: CAPWAP changed state to IMAGE
*Jan 20 20:33:58.755: %DTLS-3-BAD_RECORD: Erroneous record received from WLC-1-IP: Duplicate (replayed) record
*Jan 20 20:33:59.315: image upgrade successfully, system is now reloading
This happens again and again and again...
Regards, Manuel
-- Regards, Manuel
VIP Purple
Hi manuel,
As per my knowledge, This image is corrept...
You can try to download new image....then again try like 7.3 or 7.5.
Also chekc that Country code on ur WLC should be DE(germany)
Grüsse
Hello Sandeep,
I attached the LOG-files of several upgrade-failures of one accesspoint. but it is the same log on each AP to the original post.
And in this post... since I didn't find the upload-button...
Regards, Manuel
-- Regards, Manuel
VIP Purple
Also try this:
Please run the following commands on your WAP:
1.  delete /f /r flash:/c1240-k9w8-mx.124-23c.JA7
2.  clear capwap private
3.  reload
And then try again.
If still fails means that your Image on wlc is correcpted.
Hello everyone,
here is the result of the TAC I opened:
The third support-member I, was routed to, gave me the hint to try version 7.2.115.2 .
I did update to 7.2.115.2 and everything worked fine. :-)
Complete upgrade-path was:
Start: 6.0.199.4
1.)   1.7.0.0.FUS
2.)   7.0.240.0
3.)   7.2.115.2
4.)   7.4.110.0
5.)   7.4.121.0
6.)   7.6.100.0
His explanation why the APs did the upgrade now was:
"The reason behind this looks to be lying behind the size of the subimages for the AP in the WLC image and the preparation of the AP to accept the larger image. The 7.2.115 image should have a smaller subimage for the AP (remember what I mentioned about the limited size of 16MB on 1242 series APs) than what is being offered by the later releases like 7.4.110 etc. As we already know that the predownload doesn’t work for the 1242 APs , the space on these APs will not be cleared automatically and thus a space crunch will result in corrupt or incomplete subimage being stored. This subimage will not load after the AP boots u and thus the AP would go back to the other image option. Once the AP is booted with the subimage of 7.2.115 , it will also be prepared for the  later releases with larger subimages."
So everything is fine now, except that the APs are not accepting any config-changes from now on (this is what I see with no research done for now)... but that's another story... ;-)
Regards, Manuel
-- Regards, Manuel
Just one remark: I did not have to delete anything on the APs manually... :-)
Upgrade was done automatically as it is supposed to.
Regards, Manuel
-- Regards, Manuel
I understand.... but like we mentioned before, available flash space is the key.  So now you were able to upgrade the way you wanted, but now the AP's don't really work as you want or maybe a few.  There is no fix for that unless you have no available flash or the AP image is corrupt.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
VIP Purple
Agree with scott
1242 AP have limited flash , delete subimages and delete extra files from AP is just a wordaround from us to connect to wlc with higher versiuons but it is alwayas not successfull.
Glad that finally TAC helped you.
Grüsse
3140
