Community Member
Cisco CPI 1.2 vs 2.0 specifications
I need to answer few questions about CPI 1.2 and 2.0.
Q1: What Virtual appliance size will I get upgrading from small.ova CPI 1.2 to CPI 2.0 I do not see same parameters in data sheets.
Q2: for small CPI1.2 i need this requirements:
     Small virtual appliance
      • RAM minimum: 8 GB
      • Hard disk minimum: 200 GB
      • Processors: 4 virtual CPUs (vCPUs)
      Will I need to upgrade the HW for upgrade to 2.0?
Q3: Are licenses from 1.2 compatibile when using directly to 2.0 or I need to register them to 1.2 and then I need to upgrade to 2.0 ?
       To explain: We have WCS deployed and to upgrade we need to go to NCS add DB and then we can go to 1.2/2.0, so wheter there is a need to go to        CPI 1.2.
Q4: Are these licenses able to use for 2.0 or we need to order new ones? Is the SAU license enough?
L-PI12-LF-100-LIC
Prime   Infrastructure 1.2 - Lifecycle - 100 Device Lic PAK
N/A
L-PILMS42-100-M
Prime   Infrastructure LMS 4.2 - 100 Device Upgrade Lic
N/A
L-W-PI12-100-M
WCS to Prime   Infrastructure 1.2 Migration 100 Device
N/A
CON-SAU-PI12LF1H
SW APP SUPP +   UPGR PI 1.2 - Lifecycle - 100 Device Lic
12 month(s)
1 REPLY
---http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/2.0/quickstart/guide/cpi_qsg.html#wp46865
      • RAM minimum: 8 GB
I’m assuming you’re running a virtual machine.
The minimum requirements for PI 2.0 is 4 vCPUs, 12GB and 300 GB of disk.  You’ll have to add the resources before upgrading or the upgrade will fail
You won’t need to register with 1.2 and then to 2.0
Yes you can use the 1.2 licenses for 2.0
---Please read the link below to find more detailed info for upgrading WCS to Prime Infrastructure
https://supportforums.cisco.com/docs/DOC-26972
293
