12-27-2009 11:28 AM - edited 07-03-2021 06:22 PM
12-27-2009 01:27 PM
I did a quick google search for eap-fast module. You need version 2.2 which is compatible with 32 and 64bit windows 7.
Try it
10-06-2011 07:24 PM
Why hasn't Cisco answered this??? I'm looking through the Cisco site for an installable EAP-FAST module for Windows 7 but nothing... Why so poor of support for EAP-FAST?
10-06-2011 08:53 PM
Bob, I might suggest downloading the new Cisco Anyconnect. Cisco is leaded with the anyconnect supplicant for their wireless supplicant. You can use this to support EAP-FAST and its FREE.
Why native 7 doesnt support it is becuase its a Cisco EAP.
I hope this helps...
10-07-2011 08:32 AM
Thanks for the info. Which AnyConnect client do I download?
10-07-2011 10:15 AM
Hi Bob,
Download the latest 3.x... I have my 7 on 3.0.3054 and they work fine.
If you find this helpful if you would be so kind to rate post. And if this fixes your problem mark the question answered. It will help others during their search.
