Cisco MSE upgrade from 7.0. to 7.6.100
My original setup was 3 WCS's with 2 MSE's per WCS, We upgraded from WCS to Prime 2.0 and I am starting the MSE upgrade process.
The first MSE upgrade went fine and I was able to add it to Prime, the 2nd MSE upgrade went fine but when I try to add it to Prime I get the following message
No response from Server. It may be unreachable, or server is down or HTTPS connection to server failed.
I went ahead and upgraded the other MSE's and now I have 2 MSE's that are getting this message when I try and add them to Prime?
I have researched this error and followed everyone's suggestions but I am unable to get Prime to add those 2 MSE's..
Any suggestions would be helpful
Everyone's tags (1)
I had this problem in release
I had this problem in release 7.2.110.0 and it was helpful for me:
"Note MSE needs to be rebooted (either hard reboot or using the command shutdown -r now) after it has been upgraded to 7.2.110.0 release." (http://www.cisco.com/c/en/us/td/docs/wireless/mse/3350/release/notes/mse7_2_110_0.html#wp1113184)
I would like you to have a
I would like you to have a look on "Cisco Prime Infrastructure and Cisco Wireless Release Compatibility Matrix " from
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
293
