Community Member
Cisco PI 1.3 Assurance generate reports for applications usage
Dear,
We have the PI assurance license and currently 4 WLC's sending AVC traffic to Prime.
Strangely from the reports launch pad I'm unable to find reports that shows :
  1. Application per user / client during a certain amount of time
  2. Applications used per SSID during a certain amount of time (top application with volume)
  3. Top-talkers on a certain amount of time
I do see the AVC / Netflow data coming properly in Prime and displayed on the dashboards (Detail, end user experience, etc...).
But when using things from the reports launch pad is it either empty or I can't find the proper report.
Thanks for your suggestions
Everyone's tags (1)
1 REPLY
Community Member
I'm seeing the same, exactly
I'm seeing the same, exactly as described above. Is a significant gap, to not be able to report on the apps classified by AVC from PI. I'm assuming by the lack of response that this is just one of PI's many shortcomings that we're not really supposed to talk about? What's the point in charging for assurance licenses if you can't report on the very stuff you're monitoring?
60
