Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco Prime Infrastructure EoL/EoS and PSIRT reports
does PI 2.0 support these reports?
I have a trial version of 2.0, but can't seem to find these reports. In the release notes, it says these are supported?
New Features and Enhancements
Support for End-of-Sale/End-of-Life Lifecycle Management reports for hardware, software and modules.
Support for PSIRT reports detailing devices impacted by Cisco security advisories.
Any idea how to run these reports?
Thanks for your help
The compliance server is disabled by default. It needs to be enabled, rebooted and resync'd to be able to use psirt etc
check the report managment from the below link , it answers lot of queries including yours
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/reports/appendix_rpt.html#wp1015015
That link refers to Prime LMS 4.1 not Prime Infrastructure 2.0
Unfortunately EoL/EoS is not available within Cisco PI 2. (https://supportforums.cisco.com/message/4158676#4158676). However you can enable Compliance from the settings (somewhere) from the Administrative menu. Save and reboot the server and then you have PSIRT reports within the Compliance section in Reporting aswell.
Re: Cisco Prime Infrastructure EoL/EoS and PSIRT reports
You can use Cisco Discovery Service to create EoX reports.
http://www.netformx.com/userfiles/file/CDS2_AAG_FINAL_April2012.pdf
Hall of Fame Super Silver
You can also use the Cisco Active Advisor free tool for EoS/EoL and PSIRTs:
http://www.cisco.com/c/en/us/products/cloud-systems-management/active-advisor/index.html
Hi There, I'm not sure if we
Hi There,
I'm not sure if we are talking about the same thing, but we are running Prime Infrastructure 2.0. (2.0 (2.0.0.0.294))
You have to enable compliance from the settings (restart) and if you look under Report / Report Launch Pad, in the menu on the left is Device, click on there and you will see EOX ...... I've only had a quick look at the reports, but looks to work.
Simon
3442
