Cisco WCS - Help!
I have a requirement from a customer to report on the following events:
Note: Using WCS 6.0.181.0 and 4400 wlc with 6.0.181.0 - I've already requested updates of both to 7.0.240.0
Monitoring/Reporting/Alerting on the following:
  1. Excessive association and authentication failures
  2. Abnormal activity
  3. Misuse of the WLANs
  4. Excessive User traffic
  5. IP address Theft or Re-use
  6. Adverse Changes in Performance
Whilst point 1 and 5 I have covered, is it possible to set thresholds so that alerts will be generated for excessive user traffic? Abnormal activity and misuse of WLANs is very ambiguous but any advice would be gratefully received
BR
Rockford
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Cisco WCS - Help!
Aside from 1 and 5, the rest is NO.
2 and 4 can be done on your authentication and accounting server.  The rest is possible but it means a different solution.
1 REPLY
Cisco WCS - Help!
125
