Cisco Wireless LAN Controller 4402 under Cisco Works RME 4.0?
I am trying to manage a Cisco 4402 using non-default snmp communities from Cisco Works RME 4.0.  RME Credential Verification fails with “Device Not Supported” recorded against selected option; however, the controller does respond to snmp queries.  The 4402 has snmpv1 through snmpv3 enabled; and the snmp communities are associated with the correct client IP.  Is the WLC only responsive to snmp from the WLS and should the box be manageable via it’s management interface.  ICMP and telnet to the WLC from RME works OK.
Advice and Guidance would be greatly appreciated.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cisco Wireless LAN Controller 4402 under Cisco Works RME 4.0
What firmware version are on the WLC's..... minimum is 5.0.148 per the RME Table.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.0.5/device_support/table/RME405.html
-Scott
-Scott
Scott,
Thank you.  Our 4402 is executing 4.1.171.0.
Don't upgrade to 5.x if I were you... stick with what you have or upgrade to Cisco's gold code 4.2.207.0.  But that won't help you with the Cisco Works issue.  The latest 6.x is better than 5.x, but is still new and you will be going from lwapp to capwap:)
-Scott
512
