Cisco Wireless SSID broadcast restriction
Dear Team,
I have 12 Cisco 3602 access point and 2 Cisco 5508 WLC with HA. I want to create one new SSID which i do not need to broadcast in all pf my access point. I need to broadcast this SSID only with 3 of my access point. Kinldy advise, how will I achieve this.
Jubair.S
1 ACCEPTED SOLUTION
VIP Purple
HI Jubair,Yes you can achieve
HI Jubair,
Yes you can achieve this by creating AP groups.
Create a sepearte group and assign this ID with specific APs.
How to create, please check this post:
http://rscciew.wordpress.com/2014/01/22/configure-ap-groups-on-wlc/
Dont forget to rate helpful posts
Hall of Fame Super Gold
You'll need to create TWO
You'll need to create TWO distinct SSID.  One with broadcasting SSID and the other don't.
Don't see any benefits of hiding your SSID because a lot of free WiFi sniffers/scanners can unmask the hidden SSID very quickly.
VIP Purple
HI Jubair,
Bronze
Hello Jubair, Yes, you can
Hello Jubair,
Yes, you can create new SSID and limit them to only 3 APs
For this
1.  you have to create new WLAN profile for seperate SSID name
     WLANs > Create New > Go
2.  you have to create new group and then add all those APs in this group which you want to assign new SSID
     and call newly created profile in this group as well, that's it.
     WLANs > Advanced > AP Groups > Add Group
153
