Cisco WLC 5508 and LACP
Hi Fellows,
I wanna know if 5508 Cisco WLC support LACP or not. Actually i work in a project where i must
connect WLC 5508 in Enterasys Switches with Link Aggregation.
Enterasys Switches support LACP 802.3ad but when i learn Cisco Books i see that WLC 5508
doesn't support LACP.
Can you help please ?
Sincerely
Joseph
Tiago Antunes
Please take a look into the config guide:
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70mint.html#wp1277652.
You can read there:
Once the EtherChannel is configured as on at both  ends of the link, it does not matter if the Catalyst switch is  configured for either Link Aggregation Control Protocol (LACP) or Cisco  proprietary Port Aggregation Protocol (PAgP) because no channel  negotiation is done between the controller and the switch. Additionally,  LACP and PAgP are not supported on the controller.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
