12-14-2011 12:47 AM - edited 07-03-2021 09:14 PM
Dear experts,
we have the issue that a new WLC 5508 has been installed in a new location. Unfortunaltelly we have no hands-on suopport on-site, so just remote connection.
Now we figured that the service-port and management interfaces have to be reconfigured. In case we can not reach the WLC with the new configured interfaces it would be helpful if the WLC reboots automatically after time x to reload the previouse working configuration.
So the question is, is there a functionality to create a script which reboots the WLC automatically after time x?
Thx in advance
Solved! Go to Solution.
12-14-2011 12:57 AM
1. Command: reset system in HH:MM:SS image no-swap reset-aps save-config
2. Do your config
12-14-2011 12:57 AM
2. Do your config
12-14-2011 12:59 AM
thx for the fast reply...I'll try that.
br
12-14-2011 01:02 AM
Please don't forget to rate our useful posts. Thanks.
12-14-2011 09:44 PM
Nice work Leo .. I ll rate you ... Keep up the good work and continue to "disagree with my post" Bahahah .. +5
