Client Exclusion Policies on WLC not working with ISE as RADIUS Server
for our Guest WLAN (Security Setting for this SSID:Layer2: MAC filtering, Layer3:none) we use ISE as RADIUS Server. On WLC I enabled client exclusion polices and checked all options (Excessive 802.11 Auth. Failures etc..).. But even if a client fails 20times at authentication, it is not excluded on the wlc. It works with other SSIDs, where security settings are set to 802.1x.
Am I missing any settings here or do you have some tipps on how to troubleshoot this?
Thanks very much!
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Renata,The client
Hi Renata,
The client exclusing policies on the WLC will never be triggered. With wireless MAB & CWA or LWA, the WLC receives an RADIUS "Access_Accept" from ISE on the intial autthentication request. From this point on, as far as the WLC is concerned the client has successfully authenticated.
The intial response from ISE also includes a redirect URL and an Pre-auth ACL, to support displaying the Guest Portal on the ISE PSN.
Once ISE authenticates the guest user credentials it sends a Change of Authorization request to the WLC to reauth the client's session.
Then user session gets the Guest Access policy (Vs. intial Guest Redirect policy). At this point ISE will send a RADIUS response to WLC to remove the ACL and redirect URL from the client session.
Based on this process, failed authentications are only seen by ISE and not the WLC, so the WLC exclusion policies will never be triggered.
If you want login restrictions on Guest users, on the ISE Admin console:
Administration\Web Portal Management\Settings\Portal Policy\
Select the login restriction settings you need.
VIP Purple
Hi,Try this:The exclusion
Try this:
The exclusion timer can be enabled or disabled per WLAN.
Hi,it's already enabled. I
it's already enabled. I set it to 1800seconds. When a client authentication fails a few times on a SSID which uses 802.1x for authentication, the client gets excluded-as aspected. It just doesn't work for the SSID, which has "MAC Filtering" set as Security Policy. (The authentication happens on ISE)
Hi Renata,
Thanks for you answer. We
Thanks for you answer. We have clients, who constantly keep trying to connect without sending any credentials. Is there a way to prevent such "attacks"? under Administration\Web Portal Management\Settings\Portal Policy\   I can only apply settings based on time profiles, but we have authentication attempts as shown in the attachment. So the "guest"just leaves the credentials blank..
Kind regards
Hi Renata,If those guest
Hi Renata,
If those guest failures are not associated with valid guest users (i.e. people who have forgotten their account or entering the wrong password) there isn't anything that can be done. The main point of Guest WLAN is to make it as easy as possible for Guests - individuals with device configurations you don't want to deal with or know about, to connect your network for internet access. From a WiFi/802.11 perspective, the standard Guest WLAN setup means its easy for any device to connect.
If your Guest WLAN has the following:
SSID is broadcast enabled, Security = OPEN, Encryption = none, then any 802.11 device can find the WLAN via passive scanning and connect. And any device that connects will get the ISE portal. Once recieveing that portal they can guess away at valid username/password.
I would suspect that unless your Guest WiFi is adjacent to a Mall, school, hotel or other hi-density area of individuals  with time and electronics on their hands, other than alerts in your ops window and logs, resources associated with this (WLC & ISE) are very low.
You can try and dull the noise a few ways.
Option 1. create and ISE log filter on those alerts so they don't cluter the console.
Option 2. Stop broadcasting the SSID.  This is not a security measure, but will cut volume of people connecting to the SSID significantly. You will have to tell your guests what SSID or include it in their credential communication.
Option 3. Put a very simple PSK on the SSID. The PSK will become a public secret - shared with valid guests, doesn't have change as it's purpose is not security.  You will have to include this information on their credential communication.
Option 4 - both 2 and 3
The most effective option would be 3.
Good Luck!
Ok, thanks!
Ok, thanks!
Hi,have you ever had the
have you ever had the problem that a MACAddress cannot be added to exclusion list on WLC?
the problem are the first 4 digits...
03:00:03:52:01:52
If I change them, then it works.. otherwise I get the error message:
"Error in creating Disabled Client"
Excessive 802.11 Association
Excessive 802.11 Association Failures —Clients are excluded on the sixth 802.11 association attempt, after five consecutive failures.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0MR1/configuration/guide/wlc_cg70MR1/cg_security_sol.html#marker-1757438
I've enabled all of those
I've enabled all of those options, still no automatic exclusion, even if I trigger 15 failed attempts per a few seconds. =/
1094
