Client State: IPLEARN
I am configuring a single Catalyst 3650 switch with Aironet 3702E APs.
If I join an SSID weather its open authentication or otherwise, my devices never receive an IP address.  If I statically assign them, I cannot browse the network.
Relevent Topology:
Router > Switch A (VTP Server) > Trunk > Catalyst 3650 (VTP Client)
*Default VLAN: 1
I have the Wireless Management IP set to the VLAN 1 IP Address.
CAT3650#show wireless client summ
Number of Local Clients : 1
MAC Address    AP Name                          WLAN State              Protocol
xxxx.xxxx.xxxx APxxxx.xxxx.xxxx                 50    IPLEARN            11n(2.4)
This is the only Mobility device for the company.  I have it operating as a Mobility Controller.
Here is the conf:
version 15.0
no service pad
service compress-config
hostname CAT3650
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret x
username x privilege 15 password x
no aaa new-model
clock timezone CST -6 0
clock summer-time CDT recurring
clock calendar-valid
switch 1 provision ws-c3650-24pd
ip name-server 192.168.254.1
ip name-server 192.168.254.254
ip device tracking
crypto pki trustpoint TP-self-signed-764008471
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-764008471
revocation-check none
rsakeypair TP-self-signed-764008471
crypto pki certificate chain TP-self-signed-764008471
certificate self-signed 01
  x
        quit
diagnostic bootup level minimal
spanning-tree mode pvst
redundancy
mode sso
class-map match-any non-client-nrt-class
  match non-client-nrt
policy-map port_child_policy
class non-client-nrt-class
    bandwidth remaining ratio 10
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address 192.168.254.249 255.255.255.0
negotiation auto
interface GigabitEthernet1/0/1
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
switchport mode trunk
interface TenGigabitEthernet1/1/4
interface Vlan1
ip default-gateway 192.168.254.254
ip http server
ip http authentication local
ip http secure-server
snmp-server location x
snmp-server contact x
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
transport input telnet ssh
line vty 5 15
login local
ntp server 1.pool.ntp.org
ntp server 0.pool.ntp.org
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
wireless mobility controller
wireless management interface Vlan1
wireless client fast-ssid-change
wlan Test 50 Test
no security wpa
no security wpa akm dot1x
no security wpa wpa2
no security wpa wpa2 ciphers aes
shutdown
ap led
ap mgmtuser username xpassword 0 x secret 0 x
ap group default-group
ap group WAREHOUSE_GROUP
description Warehouse
wlan Test
end
Any help is appreciated
Hall of Fame Super Silver
Is this an updated show run?  You have the WLAN disabled
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
VIP Purple
HI John,
Do you have 'ip dhcp required' set  under your wlan config? Turn it off  and give a try.
Regrads
The shutdown command is not present while testing (no shutdown is configured)
I did see that ip dhcp required issue on another post, but I never had that checked.
I don't see that you have ip dhcp required on your config you posted... that's why I asked if that was a current config or not.
Scott
-Scott
Sorry Scott, my wording was a little off.  I mean that that under Configuration > Wireless > Test > Advanced > DHCP Address Assignment required - the box has never been checked / ip dhcp required under wlan Test 50 Test has never been configured.
I'm still having trouble with this.  Am I ok to have everything on one vlan?  Or do I need to have the wireless management address on another vlan/IP address other than the VLAN 1's ip?
I have multiple reports from
I have multiple reports from various sites running Cisco 3850 (MC) that the wireless client fails to connect to a SSID.
-The problem do not happen to all clients in the sites, only a few.
-Rebooting/Reconnecting the client sometime helps, but not all them time.
-The problem stays on a particular client (appears to be tied to Client's mac address)
-ACS shows authentication successful, but client with missing IP address.
-Cisco 3850 Client Status "sometime" shows Client in IPLEARN status and cannot be cleared.
-Cisco 3850 switch side show client making DHCP request repeatedly, and the DHCP server making multiple IP allocation to the same MAC address can be seen on the ARP table.
For this environment, the Wired and Wireless share the same VLAN and DHCP range.
S.K. Lai
1508
