Clients not receiving DHCP leases
Hello Experts,
I have 2100 series WLC with 7.0.240.0 version.
But I am not able to get lease out DHCP address, unable to get a DHCP lease from an external DHCP server.
I enabled the DHCP debug:
Here are few logs:
*DHCP Socket Task: Jan 22 20:21:11.397: b7:0b:a9:8c:4d:f9 DHCP option len (including the magic cookie) 72
*DHCP Socket Task: Jan 22 20:21:11.397: b7:0b:a9:8c:4d:f9 DHCP option: message type = DHCP INFORM
*DHCP Socket Task: Jan 22 20:21:11.397: b7:0b:a9:8c:4d:f9 DHCP option: 61 (len 7) - skipping
Anybody can help.
2 ACCEPTED SOLUTIONS
VIP Purple
When a client is in DHCP REQ state on the controller, the controller drops DHCP inform packets. The client will not go into a RUN state on the controller until it receives a DHCP discover packet from the client. DHCP inform packets are forwarded by the controller when DHCP proxy is disabled.
Enable DHCP Proxy On WLC by using thsi command:
CLI:
(Cisco Controller) >config dhcp proxy enable
GuI:
Controller > Advanced > DHCP
Select the Enable DHCP Proxy check box to enable DHCP proxy on a global basis
Please check this, if still u r facing issue then provide more info.
Can you please paste a client debug of the client having DHCP issues.
Go to cli of the wlc and run the client debug .
Dont forget to rate helpful posts
VIP Purple
Disable/Enable DHCP proxy is a system wide command it's either enabled or disabled. You can't set it per WLAN. If you are using external servers disabling proxy isn't an issue but you have to use ip helper  command configured at L3 switch.
VIP Purple
CLI:
GuI:
Thanks ..that solved my problem
But I have one more question that can I Disable/Enable DHCP Proxy per WLAN ???
VIP Purple
188
