Community Member
Compatibility requirements for PEAP, MS-CHAPv2 and Aironet basic question
Hi friends,
I just wanted to know that in the process of configuring PEAP on Cisco
Aironet 1200, when Choosing WEP Mandatory under Encryption Manager in
AP, does this ensure dynamic WEP keys?
Also, all the clients are either Windows XP SP1 or SP2. So, there is
definitely OS support for 802.1x and PEAP and EAP-MSCHAP v2. But should
I be looking for similar support in every wireless client adapter as
well?
I am not sure if such features should be checked at the OS level only
or also the adapter level also?
Thanks a lot
Gautam
1 REPLY
Hall of Fame Super Silver
Re: Compatibility requirements for PEAP, MS-CHAPv2 and Aironet b
You must first make sure the client side can support the type of encryption you require. Also make sure that the drivers are updated and try to make the wireless cards and firmware consistant to help you in case you need to troubleshoot.
Usually with PEAP MSChapV2 is also using WPA2. Note that SP1 needs a hotfix that you can install to be able to support WPA2, if not WPA is the encryption that is supported. Here is a doc that can show you how to configure PEAP on a 1200 AP. Hope this helps.
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_technical_reference_chapter09186a008025d6ee.html
WPA2 hotfix:
http://downloads.pcworld.com/pub/new/patches___drivers/WindowsXP-KB893357-v2-x86-ENU.exe
-Scott
180
