Community Member
Config WLAN override in CLI
I currently have case open with TAC where my LWAPs are losing their override settings . The workaround that I was given is to manually adding SSIDs to the override settings via the GUI. The GUI sucks for this. Can't do text search and you can't sort the columns.
Is there a command to add SSID to the override settings in CLI?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Config WLAN override in CLI
Hi Wilfred,
Using the CLI to Enable WLAN Override
To enable the WLAN Override option using the controller CLI, enter this command:
config ap wlan enable {802.11a | 802.11b} cisco_ap
To define which WLANs you wish to transmit, enter this command:
config ap wlan add {802.11a | 802.11b} wlan-id cisco_ap
From this good doc;
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40wlan.html#wp1114777
Hope this helps!
Rob
Hi Wilfred,
From this good doc;
Hope this helps!
Rob
Community Member
Also, verify the templates that are being pushed out have the correct wlan override settings if multiple people manage the WCS.
151
