11-14-2014 07:10 AM - edited 07-05-2021 01:56 AM
I tried configuring snmp string on aironet 3602E. It gets configured but movement i restart the AP, configurations are not saved. I tried using write memory command but no use.
Kindly assist
Solved! Go to Solution.
11-19-2014 12:23 AM
i want to configure snmp strrings on AP Aironet 3602
*Sigh*
We're going around in circles.
Let me repeat: You CANNOT SAVE your SNMP strings on a controller-based AP. You can configure them but when you reboot the AP, it's gone.
Exactly what SNMP details do you want to configure on the AP which you can't get using snmpget or snmpwalk?
11-19-2014 01:09 PM
Just an addition to my last post (below):
I am working with two guys who's very savy at PERL scripting. They've done a lot of SNMP configuration, both in wired and wireless network, and I've never seen them configure anything SNMP on our controller-based AP. All SNMP work are done on the WLC and it's mostly snmpget or snmpwalk.
If you need to configure SNMP strings on the AP then, rest assured, someone is doing it wrong.
11-16-2014 02:24 PM
That's because you can't save a configuration on the AP if the AP is running controller-based IOS. Controller-based AP/IOS means all configuration is on the WLC. It defeats the true purpose of controller-based IOS if one has to configure each individual AP.
11-17-2014 09:07 PM
Is it possible to configure snmp string on AP through controller?
11-18-2014 12:17 AM
If you're talking about RO & RW community string, yes you can. You've got a choice of configuring via CLI or GUI.
11-18-2014 04:18 AM
Thanks for the info..please share the commands..
11-18-2014 12:41 PM
Please do not forget to rate our posts.
11-18-2014 09:17 PM
I have already configured snmp on controller WLC 5508..i want to configure snmp strrings on AP Aironet 3602
11-18-2014 09:28 PM
You can't. Things are handled by the WLC.
A. The LAP APs cannot handle SNMP messages on their own. In order to handle SNMP messages, you should configure an SNMP community on the WLC to which the LAP is registered. All the AP information is managed by the WLC.
Scott
11-19-2014 12:23 AM
*Sigh*
11-19-2014 01:09 PM
